Wheel Polishing/Refurb....Some pics of the results from today
DodgyRog
As some of you know, I got the wheels off of Fearless's Chargespeed recently
Well after a good clean the lips are worse than I thought and I have tried to polish them back up by hand and to be honest I am not getting anywhere fast
On my build thread it was mentioned about using a machine polisher
So I am after a machine polisher, put up a wanted thread http://www.mkivsupra.net/vbb/showthread.php?288868-Electric-Rotary-Polisher
but what other things will I need, is there specific pads compounds etc
The lips have some pitting as well as hazing
Any help would be good, I would love to have these on the Supra by the Dragonball, but at the present rate I am not going to make Dragonball 20
What options do I have, I need to keep the cost to a minimum as well
Edited by DodgyRog
Title changed to reflect the new post (see edit history)
I made my old rims perfect again its hard work.. But this is the way I did it:
Very course sandpaper to rub down the uneven surface.
Then use 400 grit
Then use 400 grit + water
Then 800 grit
then 800 grit + water
Then 1200 grit
Then 1200 grit + water
Then 1500 grit + water
Then 1500 grit + Maguires metal polish
Then Maguires metal the hell out of that rim!!
Was:
http://img51.imageshack.us/img51/4682/96376895.jpg
http://img607.imageshack.us/img607/435/94777364.jpg
After:
http://img854.imageshack.us/img854/4837/48766295.jpg
Then use 400 grit
Then 800 grit
Then 1200 grit
Was:
After:
Great work on those!
I need to polish my lips, as it's time to get them back on the car. At least they're not too bad at all :)
Well I just went with a polishing wheel for the drill
Although I have not quite finished yet and I am going to have to except that I am not going to get rid of the pitting until I can afford to send them to Ibrar
They have come up okay, I need to go over them by hand, as I have a few fine scratches from the drill
This is the one I have only given a quick wash
And the one I am working on
QUICK TIP . If you got a Dremmel , use the fine attachment polisher . All my rims are curbed so i started on the worse one today. Once you,ve buffed the rim and got rid of the scratches and pitted spots, i rubbed it down with 1200 wet n dry, looks 100% better . By the way i used a Clark Rotary Tool , much better than Dremmel , with more attachments..
Spent some time yesterday and most of today on the other rear wheel
I only have about half an hour of polishing to do and it will be done
but I am doing it in the back garden and it's now peeing down, so I have had to stop.............gutted lol
Proberbly not a good idea to try and finish it with an extension lead and electric drill I guess:badidea:
This is it for this weekend then
So one to finish and these 2 to do
Edited by DodgyRog (see edit history)
I am still hand sanding with wet n dry,
240 to get the worst of the lacquer off, but not to excessive so as to not scratch up the rims to much
Then a proper work out with 600 grit
and a final 1200 grit to smooth them back a bit
then I am using a polishing wheel that came in a kit from Halfords (it was just something I could get my hands on quickly and local)
The compound bricks were very dry (not sure if they are supposed to be or not) and didn't seem to be doing much, so tried using AutoSol
The AutoSol seemed to work fine, so I have just continued with that method
Then once they are looking like the pics with the polished lip with no middle in, I go over them by hand again, this time with Britemax Easy Cut and then Final Finish
This leaves them with a nice glossy shine, I have then sealed them with a few coats of Rim Wax
I not saying this is a method people should follow or that it's a good way of doing it, as I am sure there are quicker ways, but it is working for me (to a degree) and it was using stuff I had to hand locally at minimal cost
I am not getting the pitting out with this method, just getting the mirror polish back, the pitting obviously improves, but I think I am going to send them to Ibrar in the winter (funds permitting) to get the centres Black Chromed and the lips repolished to get rid of the pitting
The polishing ring, although from Halfords, seems to be holding up well, the one connected to the drill has done 2 wheels nearly at this stage, the other is unused so far
The kit I got
Cheers for that, I'm going to polish up some stainless soon and didn't really know where to start, that is useful information to help me make a start :)
No problem, I had no idea how to do this a week or so ago, but I am really please with the results so far
Just take your time, it's a slow process, but rewarding
As I said, this may not be the best or quickest way though
Quality work there mate, they have come up really well.
Thanks a lot, I am actually really enjoying it, although it takes forever
You need a special compound for stainless or it will scratch easy! good luck
Cheers Rob,
as I have said I am no expert, so please don't just copy what I am doing blindly
Not having much work is really hard on the pocket, but it means I can see the light at the end of the tunnel with these wheels now
Weather permitting and they could be finished at the weekend, then I just need to sort out the coilovers to allow these hugely dished rims partly under my arches:cool:
Looks like I am not going to get any work today either, so I am going to wash and wax the Supra and then either do a bit more on the wheels or start on the coilovers, probably the coilovers, as it looks like the weather is going to be lovely down here today
