R3DG3CKO ROB Posted April 17, 2013 Share Posted April 17, 2013 Can anyone give me a bit of guidance? I need to wire in my new cigarette lighter so I can charge my phone/gps the stock one on the dash wasn't working and was removed and smoothed over so I thought I'd run it to the arm rest instead. Had the dash off and have found what I think are the original wires (one grey one white) but not sure how to check them? I've got a multi-meter but have never used it and honestly not sure what I need to be looking for. Other question is that the lighter I bought has a led ring to it so I've got another two wires to find I guess? Link to comment Share on other sites More sharing options...
mattdavies Posted April 17, 2013 Share Posted April 17, 2013 I would wore the lighter to a battery positive and then the LED ring to the ash try light Link to comment Share on other sites More sharing options...
scott87 Posted April 17, 2013 Share Posted April 17, 2013 The led ring is a simple live feed, id wire it into something that only comes on when the ignition is on if you even want it... And the black is just the earth. With regards to the original cig lighter wiring ive not unplugged that before.. Link to comment Share on other sites More sharing options...
R3DG3CKO ROB Posted April 17, 2013 Author Share Posted April 17, 2013 Ash tray was also removed and smoothed, I forgot about that Link to comment Share on other sites More sharing options...
scott87 Posted April 17, 2013 Share Posted April 17, 2013 There will be a remote live spare behind the cd player for the led ring. Link to comment Share on other sites More sharing options...
R3DG3CKO ROB Posted April 17, 2013 Author Share Posted April 17, 2013 Would that be the loose red wire with the bullet connector, hanging out the back of the stereo then? I'll have a look and see if that works. Link to comment Share on other sites More sharing options...
scott87 Posted April 18, 2013 Share Posted April 18, 2013 Would that be the loose red wire with the bullet connector, hanging out the back of the stereo then? I'll have a look and see if that works. Yer, or at least it was on mine. I used it for a small led on my car before. Link to comment Share on other sites More sharing options...
R3DG3CKO ROB Posted April 20, 2013 Author Share Posted April 20, 2013 Right I really have no idea what wire to look for for the actual lighter, just tested the wires i thought were the ones from the old cigarette lighter one blue/red (live) one white/green (earth?) and the multimetre says 17v so no use I'd guess? Really not that handy with wiring, can someone technical tell me what to look for and how to test the voltage? I'm guessing the wire in the second picture is the one Scott recommended for the LED? Rob Link to comment Share on other sites More sharing options...
listy Posted April 20, 2013 Share Posted April 20, 2013 There should be a grey plug that will just pop onto the actual lighter spade connectors. Can't help with the led though. Link to comment Share on other sites More sharing options...
Kaan W Posted April 20, 2013 Share Posted April 20, 2013 The cigerette lighter should be on the same circuit as the clock, it is a red/blue and white/black wire for power, all the interior ilumination circuit ie the outer ring should be white/green and green/orange. Link to comment Share on other sites More sharing options...
R3DG3CKO ROB Posted April 20, 2013 Author Share Posted April 20, 2013 (edited) Someone (cough) removed the grey plug that would make my life easy to use the wires for lighting which has now been removed. so need to establish how to wire the lighter up via spade connectors? (been told that should work fine?) but the voltage I'm getting is reading over 17v on the muti-meter? Unless I'm reading it incorrectly, which is a distinct possibility. Edited April 20, 2013 by R3DG3CKO ROB spelling error (see edit history) Link to comment Share on other sites More sharing options...
Kaan W Posted April 20, 2013 Share Posted April 20, 2013 In your first picture the 2 wires with the grey plug should be for lighting and take the other white connector off and spade connect to power the lighter. Link to comment Share on other sites More sharing options...
R3DG3CKO ROB Posted April 20, 2013 Author Share Posted April 20, 2013 I'll give that a try, cheers. I assume that the center terminal with the bolt is the positive yes? Link to comment Share on other sites More sharing options...
R3DG3CKO ROB Posted April 20, 2013 Author Share Posted April 20, 2013 That works. Does anyone know if I can share the the negative wire I'm using for the lighter for the led as well? Link to comment Share on other sites More sharing options...
Kaan W Posted April 20, 2013 Share Posted April 20, 2013 That works. Does anyone know if I can share the the negative wire I'm using for the lighter for the led as well? I would have thought so, I think the reasons there being 2 seperate wires is for different current tolerances. If its the cig lighter wire I would think it would be ok for the illumination. Link to comment Share on other sites More sharing options...
R3DG3CKO ROB Posted April 20, 2013 Author Share Posted April 20, 2013 seems to work fine, thanks for all the help everyone. Rob Link to comment Share on other sites More sharing options...
R3DG3CKO ROB Posted April 21, 2013 Author Share Posted April 21, 2013 New problem now - could what I've done have killed the car or is it more likely what I've been doing with the rear lights? Car is completely dead now and won't start Link to comment Share on other sites More sharing options...
