black_widow87 Posted June 8, 2013 Share Posted June 8, 2013 Chris Bailey said: What was the actual 1/4 mile time and speed? Best time of the day was 12.825 @ 120mph, had serious bogging down issues in 1st followed by major wheel spin in 2nd. Got what i came for so left it at that, didn't wanna temp fate!lol Link to comment Share on other sites More sharing options...
black_widow87 Posted June 8, 2013 Share Posted June 8, 2013 Rich.2211 said: Well done on the time mate! What happened to the silver Supe? I think we all agreed on it being front crank seal, dropped a fair bit of oil. Hope its an easy fix mate. Link to comment Share on other sites More sharing options...
thetrashcanman Posted June 8, 2013 Share Posted June 8, 2013 Biebs told me earlier apparently he has a small oil leak, lost about 1/3rd of a litre of oil, but didn't want to risk driving the car home, so I believe he's managed to get a mate who has a flat bed type thing to get him home Edit: Did Dave run? As I seem him there I think kindly towing Adam out Link to comment Share on other sites More sharing options...
DaveR Posted June 8, 2013 Share Posted June 8, 2013 (edited) thetrashcanman said: Did Dave run? As I seen him there I think kindly towing Adam out Yes and yes. I got to use my rear towing eye, not quite how it's intended of course (to tow rather than be towed) but still... good stuff! I matched my best time and ET from Santa Pod last month - without the benefit of Syvecs launch control, which is playing up for some reason - but despite knocking a couple of tenths off my 60' time I still wasn't ENTIRELY satisfied. I'm still convinced that given the right launch, Suki will run an 11... I have a minor issue at the moment with my DASH2 display in that the high boost warning is a bit too sensitive, so it flashes at 1.7bar - the problem being that the warning is the last 2 LEDs of the shift light sequence and that of course, if I'm hitting 1.7bar, it means I'm very nearly at the rev limit in whichever given gear, so the end result is that I'm short shifting rather than getting right up to just before the limiter. VERY frustrating!! Anyway... My best times of the day: 60'.......2.290s 1/4.......12.420s ET.........126.76mph My best 60' time of the day was 2.132s, incidentally, but the 1/4 time was 12.56s (see above for reason...). Getting better but there's still room for improvement. Edited June 8, 2013 by DaveR (see edit history) Link to comment Share on other sites More sharing options...
DaveR Posted June 8, 2013 Share Posted June 8, 2013 (edited) Oh yeah, using this equation (thanks Littler for the link ), that last run yielded Suki as having a 0-60 time of 3.15s (1/8 mile in 8.42s @ 98.02mph). I appreciate that's not COMPLETELY accurate, but still... Edited June 8, 2013 by DaveR (see edit history) Link to comment Share on other sites More sharing options...
Chris Bailey Posted June 8, 2013 Share Posted June 8, 2013 DaveR said: Yes and yes. I got to use my rear towing eye, not quite how it's intended of course (to tow rather than be towed) but still... good stuff! I matched my best time and ET from Santa Pod last month - without the benefit of Syvecs launch control, which is playing up for some reason - but despite knocking a couple of tenths off my 60' time I still wasn't ENTIRELY satisfied. I'm still convinced that given the right launch, Suki will run an 11... I have a minor issue at the moment with my DASH2 display in that the high boost warning is a bit too sensitive, so it flashes at 1.7bar - the problem being that the warning is the last 2 LEDs of the shift light sequence and that of course, if I'm hitting 1.7bar, it means I'm very nearly at the rev limit in whichever given gear, so the end result is that I'm short shifting rather than getting right up to just before the limiter. VERY frustrating!! Anyway... My best times of the day: 60'.......2.290s 1/4.......12.420s ET.........126.76mph My best 60' time of the day was 2.132s, incidentally, but the 1/4 time was 12.56s (see above for reason...). Getting better but there's still room for improvement. Still not a bad time! The car can run better though - I'll let you know what times dad runs at Japshow if we get a chance to get on the strip Link to comment Share on other sites More sharing options...
DaveR Posted June 8, 2013 Share Posted June 8, 2013 Chris Bailey said: Still not a bad time! The car can run better though - I'll let you know what times dad runs at Japshow if we get a chance to get on the strip The car is still in one piece, most importantly! Link to comment Share on other sites More sharing options...
JamieP Posted June 8, 2013 Share Posted June 8, 2013 DaveR said: Yes and yes. I got to use my rear towing eye, not quite how it's intended of course (to tow rather than be towed) but still... good stuff! I matched my best time and ET from Santa Pod last month - without the benefit of Syvecs launch control, which is playing up for some reason - but despite knocking a couple of tenths off my 60' time I still wasn't ENTIRELY satisfied. I'm still convinced that given the right launch, Suki will run an 11... I have a minor issue at the moment with my DASH2 display in that the high boost warning is a bit too sensitive, so it flashes at 1.7bar - the problem being that the warning is the last 2 LEDs of the shift light sequence and that of course, if I'm hitting 1.7bar, it means I'm very nearly at the rev limit in whichever given gear, so the end result is that I'm short shifting rather than getting right up to just before the limiter. VERY frustrating!! Anyway... My best times of the day: 60'.......2.290s 1/4.......12.420s ET.........126.76mph My best 60' time of the day was 2.132s, incidentally, but the 1/4 time was 12.56s (see above for reason...). Getting better but there's still room for improvement. With a serious launch there is a possible 10 in there, my first 10 was a 10.9 at 126mph, same terminal as you. You would need drag wheels to do it though, that's a terrible 60ft time. Link to comment Share on other sites More sharing options...
Chris Bailey Posted June 8, 2013 Share Posted June 8, 2013 DaveR said: The car is still in one piece, most importantly! Very true! - What RPM was you launching today? Link to comment Share on other sites More sharing options...
DaveR Posted June 8, 2013 Share Posted June 8, 2013 JamieP said: With a serious launch there is a possible 10 in there, my first 10 was a 10.9 at 126mph, same terminal as you. You would need drag wheels to do it though, that's a terrible 60ft time. Yup... It's REALLY frustrating too, given the ET. I know it's entirely the fleshy part behind the wheel holding things back rather than anything mechanical, because the car just FLIES after the first 60' and pretty much passes whatever is next to me (not EVERYTHING, but most...). - - - Updated - - - Chris Bailey said: What RPM was you launching today? ~3k. Link to comment Share on other sites More sharing options...
thetrashcanman Posted June 8, 2013 Share Posted June 8, 2013 DaveR said: Yes and yes. I got to use my rear towing eye, not quite how it's intended of course (to tow rather than be towed) but still... good stuff! I matched my best time and ET from Santa Pod last month - without the benefit of Syvecs launch control, which is playing up for some reason - but despite knocking a couple of tenths off my 60' time I still wasn't ENTIRELY satisfied. I'm still convinced that given the right launch, Suki will run an 11... I have a minor issue at the moment with my DASH2 display in that the high boost warning is a bit too sensitive, so it flashes at 1.7bar - the problem being that the warning is the last 2 LEDs of the shift light sequence and that of course, if I'm hitting 1.7bar, it means I'm very nearly at the rev limit in whichever given gear, so the end result is that I'm short shifting rather than getting right up to just before the limiter. VERY frustrating!! Anyway... My best times of the day: 60'.......2.290s 1/4.......12.420s ET.........126.76mph My best 60' time of the day was 2.132s, incidentally, but the 1/4 time was 12.56s (see above for reason...). Getting better but there's still room for improvement. Well done Dave, gotta love Club spirit! and that's a still a pretty good time, and as for the fleshy part behind the steering wheel letting the side down, all you need is a bit more practice mate and I'm sure you'll get her into the 11's Link to comment Share on other sites More sharing options...
Littler Posted June 8, 2013 Share Posted June 8, 2013 DaveR said: Yup... It's REALLY frustrating too, given the ET. I know it's entirely the fleshy part behind the wheel holding things back rather than anything mechanical, because the car just FLIES after the first 60' and pretty much passes whatever is next to me (not EVERYTHING, but most...). - - - Updated - - - ~3k. It did bloody launch once passed the 60ft, it just pulled, pulled and pulled!! And Dave you did hit 11's but it was the ones your tyres left behind Link to comment Share on other sites More sharing options...
DaveR Posted June 8, 2013 Share Posted June 8, 2013 Littler said: And Dave you did hit 11's but it was the ones your tyres left behind Link to comment Share on other sites More sharing options...
DaveR Posted June 8, 2013 Share Posted June 8, 2013 thetrashcanman said: as for the fleshy part behind the steering wheel letting the side down, all you need is a bit more practice mate and I'm sure you'll get her into the 11's Thanks matey. That's the dream! Link to comment Share on other sites More sharing options...
thetrashcanman Posted June 8, 2013 Share Posted June 8, 2013 DaveR said: Thanks matey. That's the dream! Its a good Dream to have, I also hope to one day do that, although I'm in no rush Link to comment Share on other sites More sharing options...
viper Posted June 8, 2013 Author Share Posted June 8, 2013 Was a great day concidering all the issues first thing. First the drag wheels not fitting over the calipers, then the misfire which turned out to be an injector wire. Then the ecu vac pipe splitting, on top of an autobox that really didn't like changing up without bouncing off the limiter several times. Over all best time was 12.051. So close to 11s. Unfortunately that wasn't then end of the bad luck, having decided I liked doing burnouts my MT streets felt differently, one picked up a puncture and the other is down to the cord. So that rules me out for tomorrow unless someone as a pair of 26 or 27x10x15 slicks? Link to comment Share on other sites More sharing options...
JamieP Posted June 8, 2013 Share Posted June 8, 2013 Got these. http://www.mkivsupra.net/vbb/showthread.php?290967-Hoosier-325-50-15-drag-radials Link to comment Share on other sites More sharing options...
Justin Bieber Posted June 8, 2013 Share Posted June 8, 2013 Finally home, just want to thank all the lads again for their help trying to get me home, the club spirit is great here! Will have a look at it tomorrow and get a better idea what's going on with it, the real kicker is that I lost my race against Littler by 0.04 of a second!! Link to comment Share on other sites More sharing options...
letmeshowyou Posted June 8, 2013 Share Posted June 8, 2013 Sounds like a fun day guys! Sorry I missed it! (Dave; there's definitely a 10 in there with enough practice and a bit of a set up change!) Link to comment Share on other sites More sharing options...
DaveR Posted June 9, 2013 Share Posted June 9, 2013 viper said: Was a great day concidering all the issues first thing. First the drag wheels not fitting over the calipers, then the misfire which turned out to be an injector wire. Then the ecu vac pipe splitting, on top of an autobox that really didn't like changing up without bouncing off the limiter several times. Over all best time was 12.051. So close to 11s. Unfortunately that wasn't then end of the bad luck, having decided I liked doing burnouts my MT streets felt differently, one picked up a puncture and the other is down to the cord. So that rules me out for tomorrow unless someone as a pair of 26 or 27x10x15 slicks? Well done on the time matey and thanks for sorting out the day - I had a great time! We all got the retrospective discount on the gate when we left, by the way. Apologies for not saying goodbye but you were still in 'man on a mission' mode and lining up for what I'm guessing must have been your 50th or so run of the day! Also, given the amount of smoke each time you lined up, I'm not particularly surprised your tyres have given up! Hope you can find something to get back on it today. Justin Bieber said: Finally home, just want to thank all the lads again for their help trying to get me home, the club spirit is great here! Will have a look at it tomorrow and get a better idea what's going on with it, the real kicker is that I lost my race against Littler by 0.04 of a second!! Glad you made it ok buddy - that's not TOO much of an obnoxious time to get back either given everything. Good luck with the fix. letmeshowyou said: Dave: there's definitely a 10 in there with LOADS more practice and probably a different driver who knows what he's doing! Adi: fixed it for you... Link to comment Share on other sites More sharing options...
DaveR Posted June 9, 2013 Share Posted June 9, 2013 Here are a couple of pics I took on the day. Wish I'd taken more, really, but you know how it is... This is the wrong flag, of course, but still looks pretty The Biebs post-issues, hooked-up and about to be towed out... Link to comment Share on other sites More sharing options...
Justin Bieber Posted June 9, 2013 Share Posted June 9, 2013 Why do i have a feeling that picture will follow me about forever?! Link to comment Share on other sites More sharing options...
DaveR Posted June 9, 2013 Share Posted June 9, 2013 Justin Bieber said: Why do i have a feeling that picture will follow me about forever?! Nah it's just the start of greater things matey. Link to comment Share on other sites More sharing options...
Justin Bieber Posted June 9, 2013 Share Posted June 9, 2013 DaveR said: Nah it's just the start of greater things matey. Ha true, I'm too far gone to let a bit of trouble stop me now, its a cracking picture though! Link to comment Share on other sites More sharing options...
Justin Bieber Posted June 9, 2013 Share Posted June 9, 2013 And here's one of yours too mate! Link to comment Share on other sites More sharing options...
