ryansupra Posted April 14, 2013 Share Posted April 14, 2013 Hi guys, I currently have her at 14 psi and have a Kakimoto cat-back and an EVC4. Was thinking of boosting her up to the limit of the stock twins to around 18 psi. Will the stock cats melt or cause trouble? I would like to leave it as legal as possible.. Link to comment Share on other sites More sharing options...
TheTurtleshead Posted April 14, 2013 Share Posted April 14, 2013 You'll kill your turbos trying to go for BPU boost levels on stock cats.... You need 2x decats and a restrictor ring(if Jspec!). Link to comment Share on other sites More sharing options...
mellonman Posted April 14, 2013 Share Posted April 14, 2013 As said temps will get too hot decat needed Link to comment Share on other sites More sharing options...
dan294 Posted April 14, 2013 Share Posted April 14, 2013 Exhaust gas temps will be dangerously high too Beaten to it!! Link to comment Share on other sites More sharing options...
ryansupra Posted April 14, 2013 Author Share Posted April 14, 2013 Ok, thanks for the input.. Anybody used a metal core high flow cat with stock twins? I know catless is the way to go but here in Canada its a big deal if you dont have cats.. Cops look for this Link to comment Share on other sites More sharing options...
shifted Posted April 14, 2013 Share Posted April 14, 2013 I know catless is the way to go but here in Canada its a big deal if you dont have cats.. Cops look for this Smash the cat out and bolt back up or even smash it out and weld in a straight pipe through it so it looks like you have a cat in there? or do you guys get emission tested? Link to comment Share on other sites More sharing options...
ryansupra Posted April 14, 2013 Author Share Posted April 14, 2013 Smash the cat out and bolt back up or even smash it out and weld in a straight pipe through it so it looks like you have a cat in there? or do you guys get emission tested? Yes, we have emission tests every 2 years, thats why i am trying to avoid removing the cats and putting them back just for the test.. And if i place a pipe in the middle, then i wont be able to pass the test at all. Anybody done an electronic dump? Some kind of electronic valve that will bypass the cats to raise boost? Link to comment Share on other sites More sharing options...
DaveR Posted April 14, 2013 Share Posted April 14, 2013 When my car was BPU I ran the first cat' and just removed the second. I had no issues whatsoever... Link to comment Share on other sites More sharing options...
FOSTA Posted April 14, 2013 Share Posted April 14, 2013 (edited) Just get decats as they are just bolt on, then when its due for emissions testing put your cats back in simples! It will not take you long to swap them out each time Edited April 14, 2013 by FOSTA (see edit history) Link to comment Share on other sites More sharing options...
shifted Posted April 15, 2013 Share Posted April 15, 2013 Yes, we have emission tests every 2 years, thats why i am trying to avoid removing the cats and putting them back just for the test.. And if i place a pipe in the middle, then i wont be able to pass the test at all. Anybody done an electronic dump? Some kind of electronic valve that will bypass the cats to raise boost? That's harsh man haha I'd change them out as necessary. Doesn't take long if you have a jack, hoist or ramps. There is a pipe/valve setup that with a flick of a switch will either exit straight after the dump (before the first cat) or if you don't flick the switch, will travel through the whole exhaust. Though I don't see how this would benefit you any further if you are going to be inspected anyway. Link to comment Share on other sites More sharing options...
ryansupra Posted April 15, 2013 Author Share Posted April 15, 2013 I'll just decat and put them back before emissions.. I guess its not that hard of a job.. Thanks for the input. Link to comment Share on other sites More sharing options...
