Boost cutting I think
andyx187
Don't think it will be fuel cut, if you think it "feels" like its pulling back, you would know if you hit fuel cut I did bpu last year and hit fuel a few times until I got my Fcd working (wired it in wrong :D) You maybe have a small boost leak when your pipes are under the highest pressure, imo check all your boost clips and all the small boost pressure pipes on the turbo side
Hi running at 1 bar boost car get to boost but feels like it pulls backm and seems to drop boost and then re boosts to 1 again it's like it's not holding any ideas
When does it drop boost? If its a twin turbo you have, the boost will momentarily drop just before turbo 2 kicks in.
May sound like I'm teaching you to suck eggs, but without knowing the spec of the car and the circumstances it occurs, its all guess work.
