safcdixon Posted April 14, 2013 Share Posted April 14, 2013 As title fellas what would/have you use(d) to fit aerocatches to a stock bonnet, would making a start hole hole with a drill and using jigsaw be the best option? when I fitted them to my carbon one I used an angle gringer and then cut away the rest with a copeing saw which isn't really doable with aluminium? Suggestions please I don't want to ruin it Quote Link to comment Share on other sites More sharing options...
SupraD06 Posted April 14, 2013 Share Posted April 14, 2013 If it was me i would drill plenty of little holes rather than one hole and then risk trying to cut out the rest with the jigsaw. I would have thought that if the blade was to struggle or bite while your going around the curves it might try to jump up and pull/dent the bonnet. But at least with plenty of small holes it only cuts through a few millimeters at a time. Ive got a set to fit to a stock bonnet myself and that's how i will be tackling it. Quote Link to comment Share on other sites More sharing options...
safcdixon Posted April 14, 2013 Author Share Posted April 14, 2013 SupraD06 said: If it was me i would drill plenty of little holes rather than one hole and then risk trying to cut out the rest with the jigsaw. I would have thought that if the blade was to struggle or bite while your going around the curves it might try to jump up and pull/dent the bonnet. But at least with plenty of small holes it only cuts through a few millimeters at a time. Ive got a set to fit to a stock bonnet myself and that's how i will be tackling it. Sounds like a plan il be doing this job some time this coming week, yeah your right more holes the better, it was a pain on the carbon one but easy to fix if something went wrong, where as the Ali bonnet wont be so easy to fix. Quote Link to comment Share on other sites More sharing options...
listy Posted April 14, 2013 Share Posted April 14, 2013 Plenty of holes and a hack saw blade? Would take longer, but minimises the risk of pulling the ali. Quote Link to comment Share on other sites More sharing options...
safcdixon Posted April 14, 2013 Author Share Posted April 14, 2013 Thats what i did with the carbon one but with a copeing saw so i could cut the round eges, Ali is fairly soft metal, but twould it be cutable with just a blade? Quote Link to comment Share on other sites More sharing options...
listy Posted April 14, 2013 Share Posted April 14, 2013 safcdixon said: Thats what i did with the carbon one but with a copeing saw so i could cut the round eges, Ali is fairly soft metal, but twould it be cutable with just a blade? Only one way to find out Quote Link to comment Share on other sites More sharing options...
Steve Paine Posted April 14, 2013 Share Posted April 14, 2013 I have just fitted to my carbon fibre bonnet and would suggest doing a search on here. There is a guide that I followed, I think by hodge? Drill loads of holes to the template and then file off. Be careful though as it took a lot of fettling to get the pins in the right place and the front lug part on the catch needs taking out otherwise the pin won't engage properly. I will have a search and see if I can find the link. It was very helpful! Quote Link to comment Share on other sites More sharing options...
Pulley Posted April 14, 2013 Share Posted April 14, 2013 fitted them to my stock bonnet i just drilled a load of small holes with my dremel then snipped the bits between with side cutters then used the dremel with a spinny sanding wheel to take the edges upto my template lines Quote Link to comment Share on other sites More sharing options...
safcdixon Posted April 14, 2013 Author Share Posted April 14, 2013 Cheers guys certainly have some options now so will see what works out best Quote Link to comment Share on other sites More sharing options...
Steve Paine Posted April 14, 2013 Share Posted April 14, 2013 Just for your info I located the pin first. Then put masking tape over the top of the bonnet. Secured the catch on top off the bonnet by the pin and then marked out the shape from the catch itself. It took me the best part of 3 hours to do before I was happy with the result. But I am not the best at doing this sort of thing. Picture of them fitted. They did come with backing plate with nylock nuts! http://i1353.photobucket.com/albums/q666/stevepaine1/Supra%20tidy%20up/D9264D1B-051E-4429-B408-C1B29B8466F6-2820-000001BC9D3FC2A8_zps1c19f4eb.jpg Quote Link to comment Share on other sites More sharing options...
safcdixon Posted April 14, 2013 Author Share Posted April 14, 2013 I alreay have the pins fitted as i had a trd carbon bonnet fitted before just changed it back to a stock one, so have a headstart on it already Its always a nervous moment cutting into a bonnet though Quote Link to comment Share on other sites More sharing options...
Pulley Posted April 14, 2013 Share Posted April 14, 2013 safcdixon said: I alreay have the pins fitted as i had a trd carbon bonnet fitted before just changed it back to a stock one, so have a headstart on it already Its always a nervous moment cutting into a bonnet though so you going to make a cardboard template of the trd catch position relative to the corner edges so you get the pin position correct for the ali bonnet catches? Quote Link to comment Share on other sites More sharing options...
safcdixon Posted April 14, 2013 Author Share Posted April 14, 2013 Pulley said: so you going to make a cardboard template of the trd catch position relative to the corner edges so you get the pin position correct for the ali bonnet catches? Im dubious about doing that as carbon/fibre bonnets are very rarely a perfect fit, so im not fully confident that it would be accurate Quote Link to comment Share on other sites More sharing options...
Pulley Posted April 14, 2013 Share Posted April 14, 2013 safcdixon said: Im dubious about doing that as carbon/fibre bonnets are very rarely a perfect fit, so im not fully confident that it would be accurate true, probably better to do a template measurement from edge of wing and headlight or something that gives good solid position Quote Link to comment Share on other sites More sharing options...
SupraD06 Posted April 14, 2013 Share Posted April 14, 2013 Here's Hodge's guide on fitting them mate, Best way to work out where to drill is to over extend the pin, then put something like bluetac or something on the top of the pin and CAREFULLY lower the bonnet down onto it to show you where to drill. Then you can just use a small pilot drill to drill back from the underside, and then when your happy your directly over the top of it you can drill it out with a bigger drill. POST #2469 http://www.mkiv.co.uk/vbb/showthread.php?196108-Hodge-s-%28The-Kraken%29-Supra-build/page62 Quote Link to comment Share on other sites More sharing options...
safcdixon Posted April 14, 2013 Author Share Posted April 14, 2013 Pulley said: true, probably better to do a template measurement from edge of wing and headlight or something that gives good solid position Yeah thats what i did last time, just make a template from one side and flip it over for the opposite side Quote Link to comment Share on other sites More sharing options...
mclarenross Posted April 15, 2013 Share Posted April 15, 2013 When you've finished practising on your motor..... you want to do mine next! lol Quote Link to comment Share on other sites More sharing options...
safcdixon Posted April 15, 2013 Author Share Posted April 15, 2013 mclarenross said: When you've finished practising on your motor..... you want to do mine next! lol Hell no lol that bonnet of yours is a work of art, il give you the template once im done though Ross Quote Link to comment Share on other sites More sharing options...
mclarenross Posted April 15, 2013 Share Posted April 15, 2013 safcdixon said: Hell no lol that bonnet of yours is a work of art, il give you the template once im done though Ross deal ! Quote Link to comment Share on other sites More sharing options...
listy Posted March 14, 2014 Share Posted March 14, 2014 I've just fitted aerocatches to my new stock bonnet. WHAT A BALL ACHE!!!!!!!!! At least with a carbon bonnet it's only two layers. Three on a stock bonnet, and each layer is tacked to the other. Took me three hours to fit one catch. The second went much quicker, as I made a template and flipped it, but oh my days, I will NEVER fit aerocatches to a stock bonnet again! Quote Link to comment Share on other sites More sharing options...
Kaan W Posted March 14, 2014 Share Posted March 14, 2014 listy said: I've just fitted aerocatches to my new stock bonnet. WHAT A BALL ACHE!!!!!!!!! At least with a carbon bonnet it's only two layers. Three on a stock bonnet, and each layer is tacked to the other. Took me three hours to fit one catch. The second went much quicker, as I made a template and flipped it, but oh my days, I will NEVER fit aerocatches to a stock bonnet again! I told you it was a nightmare!! Lol. Quote Link to comment Share on other sites More sharing options...
safcdixon Posted March 14, 2014 Author Share Posted March 14, 2014 Its one of the worst jobs ive ever done on any car, total pain and very easy to cock up which pressurises the job even more Quote Link to comment Share on other sites More sharing options...
