Josh42 Posted April 13, 2013 Share Posted April 13, 2013 Hi all, intermittently,when i push the clutch down while driving the revs will drop so low the car cuts out. I've taken the idle control valve out and cleaned it and even tried another. Does anyone have any suggestions as to what else it could be? Cheers! Quote Link to comment Share on other sites More sharing options...
listy Posted April 13, 2013 Share Posted April 13, 2013 Coil pack clips? Coil packs? Plugs? Ingniter? I'd start with coil pack clips mate. Cheapest option Quote Link to comment Share on other sites More sharing options...
Josh42 Posted April 13, 2013 Author Share Posted April 13, 2013 Forgot to mention I'm only running NA at the moment! Quote Link to comment Share on other sites More sharing options...
Josh42 Posted April 13, 2013 Author Share Posted April 13, 2013 Coil pack clips? Coil packs? Plugs? Ingniter? I'd start with coil pack clips mate. Cheapest option Forgot to mention I'm still only NA dude running Dizzy setup for now! Cheers though! Quote Link to comment Share on other sites More sharing options...
listy Posted April 13, 2013 Share Posted April 13, 2013 In that case, HT leads? plugs? Quote Link to comment Share on other sites More sharing options...
Josh42 Posted April 13, 2013 Author Share Posted April 13, 2013 Would that be an intermittent issue though? Ill swap them all over and give it a go! Quote Link to comment Share on other sites More sharing options...
listy Posted April 13, 2013 Share Posted April 13, 2013 Or O2 sensor? Mine has an intermittent groggy idle, and I've replaced plugs, coil pack clips, and my next step is to remove the O2 sensor and either clean or replace. Quote Link to comment Share on other sites More sharing options...
Josh42 Posted April 13, 2013 Author Share Posted April 13, 2013 Ill take a look tomorrow then dude:thumbs: thanks for the suggestions! Quote Link to comment Share on other sites More sharing options...
