high revving on starting....help please
sammytruck
Hi all, has anyone experienced high revs right from start up ?.
I have a '99 tiptronic, mapped around the 600 mark. Ryan mapped the car so I am sure its nothing to do with the recent mapping.
On starting, the engine will try to rev up quite high, I turn the engine off instantly, reset alarm on and off then try again.
sometimes it will rev 3-4 times before starting normally, other times its fine first go.
i thought it was the alarm, I had the old Clifford 300, so I had a new Clifford 650 concept fitted....still the same.
If anyone can help I would be very gratefull....thanks.
The VVTi doesn't have an idle control valve, it uses the fly-by-wire throttle to control the idle. Sounds like the FBW throttle is going wide open for some reason. The throttle cable and butterfly cam aren't solidly connected to the actual throttle butterfly, so that being closed does not necessarily equal the butterfly is closed.
