_Shane_ Posted April 12, 2013 Share Posted April 12, 2013 Hi All, I have the T51 kit fitted to my supra and the plan tomorrow is to fire up the car with the new kit for the first time What should i do in regards to oil / water flow for the turbo??? Anything else i should look out for thanks in advance Shane Link to comment Share on other sites More sharing options...
Kaan W Posted April 12, 2013 Share Posted April 12, 2013 Hi All, I have the T51 kit fitted to my supra and the plan tomorrow is to fire up the car with the new kit for the first time What should i do in regards to oil / water flow for the turbo??? Anything else i should look out for thanks in advance Shane What exactly do you mean mate, where the lines go? Monitering pressure? Link to comment Share on other sites More sharing options...
_Shane_ Posted April 12, 2013 Author Share Posted April 12, 2013 The oil / water feeds and returns are all new with no water or oil in them and i want to make sure there is water/ oil going to the turbo upon start up, i dont want to starve the turbo of oil/water etc Link to comment Share on other sites More sharing options...
a98pmalcolm Posted April 12, 2013 Share Posted April 12, 2013 Prime the turbo is always adviseable mate.. Link to comment Share on other sites More sharing options...
tooquicktostop Posted April 12, 2013 Share Posted April 12, 2013 Prime the turbo is always adviseable mate.. Agree turn over with no spark until everything is primed up, check oil and water is flowing Link to comment Share on other sites More sharing options...
Ian C Posted April 12, 2013 Share Posted April 12, 2013 Agree turn over with no spark until everything is primed up, check oil and water is flowing Turning it over with no fuel is better No borewash on an already oil-free block. Just pull the fuel pump plug and crank merrily away. Link to comment Share on other sites More sharing options...
supra matt Posted April 12, 2013 Share Posted April 12, 2013 The best way is to remove the air filter and hold the compressor wheel while somone starts the car hold it for around 30s before releasing. Link to comment Share on other sites More sharing options...
RobUK Posted April 12, 2013 Share Posted April 12, 2013 Turning it over with no fuel is better No borewash on an already oil-free block. Just pull the fuel pump plug and crank merrily away. I managed this by accident missed one of the washers between the fuel line and fuel filter so ended up with about 2 litres of fuel on the garage floor :S - primed everything really nicely though Link to comment Share on other sites More sharing options...
_Shane_ Posted April 18, 2013 Author Share Posted April 18, 2013 Going to start the car this evening, was told to pour a tea spoon of oil into the oil feed and then spin the compressor, leave the oil return off when starting it up first time to make sure oil is flowing through the turbo If i just unplug the coilpacks will that be enough? Thanks guys Link to comment Share on other sites More sharing options...
JamieP Posted April 18, 2013 Share Posted April 18, 2013 Do what Ian said. Link to comment Share on other sites More sharing options...
