Alex Posted April 12, 2013 Share Posted April 12, 2013 Which rear bar's DO NOT intrude into the boot? I don't want mine on show. Ta Quote Link to comment Share on other sites More sharing options...
bradleyh_15 Posted April 12, 2013 Share Posted April 12, 2013 would you not just put your carpet over it? Mine is a Tein one and is very low and you would hardly know that it was their if you put the carpet over the top Quote Link to comment Share on other sites More sharing options...
JZ480 Posted April 12, 2013 Share Posted April 12, 2013 (edited) Not sure how you would hide it from view. I know the straight cusco ones are lower profile but still very visible. Which rear bar's DO NOT intrude into the boot? I don't want mine on show. Ta Edited April 12, 2013 by JZ480 (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest Nicholas Posted April 12, 2013 Share Posted April 12, 2013 I don't think any sit flat enough to not protrude Alex. You could go for a really nice Carbon rear cusco one. http://www.tunershop.fr/tunershop/images/660551A.JPG Quote Link to comment Share on other sites More sharing options...
Alex Posted April 12, 2013 Author Share Posted April 12, 2013 Well as low as possible then... That Cusco looks like it's close to what I want. The DoLuck looks low too...but it's mega bucks. Quote Link to comment Share on other sites More sharing options...
Nic Posted April 12, 2013 Share Posted April 12, 2013 As said I don't think there are any that would fit underneath the carpet. The Carbing rear brace sits lower than most, they also bolt to the cross member for extra rigidity, very light in weight too. http://img267.imageshack.us/img267/9499/p3150092tz6.jpg http://img508.imageshack.us/img508/1822/p3310126fu8.jpg http://img508.imageshack.us/img508/1295/p3310127nj1.jpg Quote Link to comment Share on other sites More sharing options...
Westy Posted April 12, 2013 Share Posted April 12, 2013 As said I don't think there are any that would fit underneath the carpet. The Carbing rear brace sits lower than most, they also bolt to the cross member for extra rigidity, very light in weight too. http://img267.imageshack.us/img267/9499/p3150092tz6.jpg http://img508.imageshack.us/img508/1822/p3310126fu8.jpg http://i271.photobucket.com/albums/jj152/DodgyRogSupra/DSC000171.jpg http://img508.imageshack.us/img508/1295/p3310127nj1.jpg I have the DoLuck one fitted which is exactly the same as the Carbing. Sits flush with the surface if the carpet and out of them all would be the one that would sit the lowest IMO Quote Link to comment Share on other sites More sharing options...
Alex Posted April 12, 2013 Author Share Posted April 12, 2013 (edited) Nic, can you get Carbing ones? And if we're looking that that I may need TRD ARB's after an expensive chat with CW! Just found out by chance the bar I have across the top of the rear seats is an "Abflug Rear Hatch Reinforcement Bar" - Or Abflug Decapitation Bar as I call it. Edited April 12, 2013 by Alex (see edit history) Quote Link to comment Share on other sites More sharing options...
DodgyRog Posted April 12, 2013 Share Posted April 12, 2013 I have the Carbing one also and it only just sits above the carpet I can't see that any will be lower than this Before I cut the carpet Quote Link to comment Share on other sites More sharing options...
JZ480 Posted April 13, 2013 Share Posted April 13, 2013 Sorry to hijack the thread but how much is the do luck one? and the carbon cusco one? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 13, 2013 Share Posted April 13, 2013 If anyone cares to consider the tension and compression loadings across the rear strut tops they will realise any of these are a total waste of time and money. The loadings are vertical or lozenge torsional, and that bit of ill conceived soft oval alloy tube will do nothing save what some have realised, get in the way. Quote Link to comment Share on other sites More sharing options...
sideexitsupra Posted April 13, 2013 Share Posted April 13, 2013 If anyone cares to consider the tension and compression loadings across the rear strut tops they will realise any of these are a total waste of time and money. The loadings are vertical or lozenge torsional, and that bit of ill conceived soft oval alloy tube will do nothing save what some have realised, get in the way. Play fair Mr Wilson, they look nice, especially the carbon one............... Quote Link to comment Share on other sites More sharing options...
Alex Posted April 14, 2013 Author Share Posted April 14, 2013 Chris, appreciate your comments... will bear it in mind. On a side note if someone made an X brace using the turret tops and the rear seatbelt top mounts (where the belt comes out of the plastic) would this have a positive effect or again not add the desired effect? Just curious. Quote Link to comment Share on other sites More sharing options...
