Sheefa Posted April 10, 2013 Share Posted April 10, 2013 All Quick bit of help please. Fitted the Facelift Lights and as you can see there is a noticeable gap - about 1cm between bodywork and silicone edge of light unit. Tried all sorts of fitting combincations here and cannot work it out. Surely the plastic clips/lugs cannot fit behind the bodywork and must sit on top like so? Alternatively has anyway chopped these off for a more flush fit? Help. Thanks. G Quote Link to comment Share on other sites More sharing options...
Westy Posted April 10, 2013 Share Posted April 10, 2013 Don't chop them...they will fit mate. You should slide that side into place first and finger tighten the bolts, straighten it out and bolt it up tight. Under 5 mins should do it if everything goes to plan. Quote Link to comment Share on other sites More sharing options...
Sheefa Posted April 10, 2013 Author Share Posted April 10, 2013 Cheers Mark. Looks like there's too much silicone on the gap then preventing them lugs from sliding under the bodywork. Will try Sunday Quote Link to comment Share on other sites More sharing options...
heckler Posted April 10, 2013 Share Posted April 10, 2013 theres a plastic locating lug on that side, sometimes it get bent over or not located properly so gives what you see.. Quote Link to comment Share on other sites More sharing options...
Sheefa Posted April 10, 2013 Author Share Posted April 10, 2013 theres a plastic locating lug on that side, sometimes it get bent over or not located properly so gives what you see.. Cheers Si Quote Link to comment Share on other sites More sharing options...
