na plug change
james_cbr
six 12mm bolts on the y pipe, 4 on top 2 below (also x4 nuts on the exhaust side bracket).....there are a couple of rubber pipes that are fiddly to reach/remove, also the front large clipped up pipe is a coolant pipe and so i'd have something ready to soak up the spillage as you don't really want water down in the spark plug wells. (proper way is to drain a litre or so from the rad tap)
http://www.mkivsupra.net/vbb/showthread.php?4262-S-Plugs&highlight=spark
Edited by Scooter (see edit history)
Make sure NOTHING has been dropped and left in the spark plug wells ......last thing you want is to take plug out and something falls past and ends up inside :eek:
Yes watch for that also don't assume somebody else has dropped something down there
I used an air line to blow out before removing the plugs
