front indicator light help
peter richards
I take it you haven't looked at it yet?
When you do you'll see the two bolts , one on each side of the indicator. Theres one more on the top of the unit .
You should be able to get your hand in from underneath the indicator to get the top one
JIC fudge the indicators to pas sthe SVA test (apparently) by removing one outer fixing and elongating the top hole so that the whole unit swivels forward and out like Terminator described. One of mine was wobbly too.
I removed the top fixing and pushed the lamp back into the "stock" position.
