HELP!! nut type/size on A/T flange to prop shaft
Pedroby
Tried a few local Toyota dealers but they all seem to see water burning when I ask them for a simple nut and dont have a chassis number for them as my car has undergone a GE---> GTE swap.
What I need are the nuts to connect the propeller shaft on the flange of the auto gearbox on a Supra GTE gear box.
Seems quite easy to me, also as I can find pics of it easily in the manual.
But after I tried different type of nuts, I still haven't found the right ones!
I already tried M12, M12 x 1.25 but both were not the right ones. They seem to fit, but when you try to tighten them, the nuts come loose. And no my tread is not damaged :)
Please help me out what nut size and type I need!!
  • 2 weeks later...
You must use the correct nuts AND the correct ground and hardened washers. Otherwise it WILL come loose. I don't have the part numbers, but they are the same on ALL six speed MKIV's. You need to find a proper Toyota parts department, I finally trained mine to be pretty good and efficient :)
