Pedroby Posted April 8, 2013 Share Posted April 8, 2013 Tried a few local Toyota dealers but they all seem to see water burning when I ask them for a simple nut and dont have a chassis number for them as my car has undergone a GE---> GTE swap. What I need are the nuts to connect the propeller shaft on the flange of the auto gearbox on a Supra GTE gear box. Seems quite easy to me, also as I can find pics of it easily in the manual. But after I tried different type of nuts, I still haven't found the right ones! I already tried M12, M12 x 1.25 but both were not the right ones. They seem to fit, but when you try to tighten them, the nuts come loose. And no my tread is not damaged Please help me out what nut size and type I need!! Quote Link to comment Share on other sites More sharing options...
Pedroby Posted April 10, 2013 Author Share Posted April 10, 2013 Nobody?? Quote Link to comment Share on other sites More sharing options...
leeg Posted April 22, 2013 Share Posted April 22, 2013 have you tried the equivalent and af size? may not be metric? Quote Link to comment Share on other sites More sharing options...
supra900bhp Posted April 22, 2013 Share Posted April 22, 2013 Hi there I have had a word with my toyota dealer and for the 2jz-gte gearbox the part number for them nuts should be T90179-11017 x4 or however many your after and he said should be around the £2.13 each mark hope it sorts you out??? Quote Link to comment Share on other sites More sharing options...
David P Posted April 22, 2013 Share Posted April 22, 2013 I have a new set you can have for £10 inc P&P? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted April 23, 2013 Share Posted April 23, 2013 You must use the correct nuts AND the correct ground and hardened washers. Otherwise it WILL come loose. I don't have the part numbers, but they are the same on ALL six speed MKIV's. You need to find a proper Toyota parts department, I finally trained mine to be pretty good and efficient Quote Link to comment Share on other sites More sharing options...
