viper Posted April 6, 2013 Share Posted April 6, 2013 Hi all, im fitting my T04R kit at the moment, i had to remove the box so just pulled the engine out as well to save faffing with tight spaces. Iv removed the stock twins and fitted the manifold and T04R turbo, as it not water cooled i have a number of water lines and pipes im really not sure to do with that are still attached to the block along with lots of other bits and bobs im a little unsure of what to do with. Please could you review the images below and give me some advice, i think i may have chewed off a bit more than i can chew with this project so any help or advice would be realy appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
a98pmalcolm Posted April 6, 2013 Share Posted April 6, 2013 I remember blocking alot of mine off when I fitted my single.. Quote Link to comment Share on other sites More sharing options...
viper Posted April 6, 2013 Author Share Posted April 6, 2013 Anybody? I may need advice regarding picture 4 and the electrics Quote Link to comment Share on other sites More sharing options...
T14PPA Posted April 6, 2013 Share Posted April 6, 2013 This helped me alot http://www.lexusclub.co.uk/singleturbo.htm Quote Link to comment Share on other sites More sharing options...
viper Posted April 6, 2013 Author Share Posted April 6, 2013 That was helpful thanks, I still need help with the electric bits in picture 4 Quote Link to comment Share on other sites More sharing options...
listy Posted April 6, 2013 Share Posted April 6, 2013 I've not done a single build (yet ) but if I remember correctly, what you have there in pic 4 is the wastegate actuator? I think. If you are running an external wastegate (i think you need to when single?) then I *think* it either a) gets blocked off, or b) gets removed. The plugs for it also end up surpless to requirements. DO NOT CHOP ANYTHING UP BECAUSE OF WHAT I HAVE SAID, I MAY BE WRONG!!!!!!! Quote Link to comment Share on other sites More sharing options...
viper Posted April 7, 2013 Author Share Posted April 7, 2013 Thanks buddy, I beleive you right. Can anyone else confirm please? Quote Link to comment Share on other sites More sharing options...
Slutters Posted April 7, 2013 Share Posted April 7, 2013 Right the connections in pic 4, leave them all unplugged, if your running AEM you can use the blue plug as boost control, if not leave it unplugged. Quote Link to comment Share on other sites More sharing options...
viper Posted April 7, 2013 Author Share Posted April 7, 2013 I'm using a MAP ecu so I guess I unplug and everything and block everything else off, as ill be using an avcr for boost control Quote Link to comment Share on other sites More sharing options...
Hartmann Posted April 7, 2013 Share Posted April 7, 2013 just block every waterline and leave the electronic disconected .. Quote Link to comment Share on other sites More sharing options...
