james_cbr Posted April 5, 2013 Share Posted April 5, 2013 how can i tell if my car has lsd or not with out going by the chasis plate As we all know how mod happy japs are Link to comment Share on other sites More sharing options...
Dnk Posted April 5, 2013 Share Posted April 5, 2013 Light the tyres up and see if both wheels spin Link to comment Share on other sites More sharing options...
james_cbr Posted April 5, 2013 Author Share Posted April 5, 2013 tryed that think the tyres are to good back end jumped up then droped down and just griped Link to comment Share on other sites More sharing options...
JasonR24 Posted April 5, 2013 Share Posted April 5, 2013 tryed that think the tyres are to good back end jumped up then droped down and just griped or its not got enough power....... .........just kidding! Link to comment Share on other sites More sharing options...
james_cbr Posted April 5, 2013 Author Share Posted April 5, 2013 or its not got enough power....... .........just kidding! it has more power than my last car but would love to drop the twin in one day Link to comment Share on other sites More sharing options...
Dnk Posted April 5, 2013 Share Posted April 5, 2013 I see its an na try doing it on wet grass Link to comment Share on other sites More sharing options...
listy Posted April 5, 2013 Share Posted April 5, 2013 i see its an na Try doing it on wet grass Link to comment Share on other sites More sharing options...
Dnk Posted April 5, 2013 Share Posted April 5, 2013 Link to comment Share on other sites More sharing options...
james_cbr Posted April 5, 2013 Author Share Posted April 5, 2013 i did fined that vid but wasent shore if the same aplyed to supra can you conferm this is true on a supra ? Link to comment Share on other sites More sharing options...
Kaan W Posted April 5, 2013 Share Posted April 5, 2013 I see its an na try doing it on wet grass I want to know this also, although both wheels spin one wheel leaves more rubber than the other side, this would be a non lsd I take it? Link to comment Share on other sites More sharing options...
JasonR24 Posted April 5, 2013 Share Posted April 5, 2013 I want to know this also, although both wheels spin one wheel leaves more rubber than the other side, this would be a non lsd I take it? That sounds like what an LSD should do? Link to comment Share on other sites More sharing options...
james_cbr Posted April 5, 2013 Author Share Posted April 5, 2013 That sounds like what an LSD should do? thats what i would have thort as it dosent lock them together just makes shore one dosent spin that much more than the other rather than leaveing 1 rubberline Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted April 5, 2013 Share Posted April 5, 2013 Go somewhere quiet, stick one wheel on the road, other side on some grass or gravel and light them up. If the one on the road spins too, then it's an LSD. Link to comment Share on other sites More sharing options...
james_cbr Posted April 5, 2013 Author Share Posted April 5, 2013 im likeing that idea Link to comment Share on other sites More sharing options...
Pulley Posted April 5, 2013 Share Posted April 5, 2013 The Torsen LSD will feel like its working to stop the inside wheel spinning if you turn round in a tight circle or roundabout, or out of a turning, floor it in 1st aggressively and if its an open diff it wheel spin up the inside wheel Link to comment Share on other sites More sharing options...
Scooter Posted April 5, 2013 Share Posted April 5, 2013 You don't have one.....your chassis plate says A01A does it not... Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted April 5, 2013 Share Posted April 5, 2013 You don't have one.....your chassis plate says A01A does it not... And no one has ever swapped over a non LSD for an LSD? Really? Link to comment Share on other sites More sharing options...
james_cbr Posted April 5, 2013 Author Share Posted April 5, 2013 And no one has ever swapped over a non LSD for an LSD? Really? hence me reson for trying to fined out as we know how mod happy the japs are Link to comment Share on other sites More sharing options...
adarmo Posted April 5, 2013 Share Posted April 5, 2013 Find a T junction so you can turn a sharp right. Give it some revs and drop the clutch. If the back end steps out it's got an LSD. If one wheel spins you haven't. Link to comment Share on other sites More sharing options...
james_cbr Posted April 5, 2013 Author Share Posted April 5, 2013 Find a T junction so you can turn a sharp right. Give it some revs and drop the clutch. If the back end steps out it's got an LSD. If one wheel spins you haven't. usuly dose slide out when i do that Link to comment Share on other sites More sharing options...
Scooter Posted April 5, 2013 Share Posted April 5, 2013 And no one has ever swapped over a non LSD for an LSD? Really? Of course they have but the previous owner deffo didn't do it as he spent near on a grand replacing the rusty aftermarket exhaust with a brand new cat back direct from Toyota...the car was also on stock 16's and so was as stock as they come. If it had looked like a car that had been through the hands of many a modifier then my opinion may have been more circumspect as it is, in this instance and having seen the actual car and met the previous owner I felt confident that the vin plate could be trusted. Sorry if I seemed blunt... Link to comment Share on other sites More sharing options...
james_cbr Posted April 6, 2013 Author Share Posted April 6, 2013 Yeh but he also said he put the exhaust on to replace an hks exhaust witch had split in a pipe And ive found alot of wireing under the dash thats veen put in and a misterious switch witch i have to work oit what it dose Link to comment Share on other sites More sharing options...
james_cbr Posted April 9, 2013 Author Share Posted April 9, 2013 going by that vid my wheels turn agenst each other so no lsd 1 more thing to add to my list of things to get Link to comment Share on other sites More sharing options...
