Scutch0 Posted April 5, 2013 Share Posted April 5, 2013 Is the timing belt the same on the na as the tt? Also how often is it recommended to change the tensioner? Quote Link to comment Share on other sites More sharing options...
Iky Posted April 5, 2013 Share Posted April 5, 2013 Yes belt is same. Tensioner should be changed with the belt, every 60k miles/100k meters Water pump as well. But im not 100% certain if they are the same. Quote Link to comment Share on other sites More sharing options...
supra900bhp Posted April 5, 2013 Share Posted April 5, 2013 Is the timing belt the same on the na as the tt? Also how often is it recommended to change the tensioner? as said mate belt is the same 2x tensionners with or without dampener and also water pump 2x na or tt water ports are different if remember right? I have done all 3 parts only as I dont think ever been changed on mine but would go for the tensioner as the bearings are known for going hope it helps Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted April 5, 2013 Share Posted April 5, 2013 Water pump as well. But im not 100% certain if they are the same. You dont have to change the water pump, but it makes sense while its exposed. Quote Link to comment Share on other sites More sharing options...
