Jamesc183 Posted April 1, 2013 Share Posted April 1, 2013 Because I don't have many exhaust shops round me that can do mandrel 3" bends anyone know somewere that does an off the shelf 3" system for an N/A? Link to comment Share on other sites More sharing options...
Nic Posted April 1, 2013 Share Posted April 1, 2013 (edited) The only difference between the NA and TT exhaust is the 1st cat, the 2nd cat and cat back exhausts are the same fit. There are many 3" exhausts designed for the TT that will fit but they'll be VERY loud on an NA. A 3" diameter exhaust is also likely to have a poor effect on performance, you will get better results with a narrower diameter exhaust designed specifically for the NA such as the Blitz NUR R http://www.blitz-uk.co.uk/ProductItem-2419.aspx If you do decide on a 3" exhaust, Blitz, HKS, Apexi and Tanabe all do off the shelf ones for the Supra, you could also try contacting Paul at Whifbitz (see traders section) who can get exhausts made to your own spec. Edited April 1, 2013 by Nic (see edit history) Link to comment Share on other sites More sharing options...
