ashbuster Posted March 30, 2013 Share Posted March 30, 2013 ill be changing the power steering fluid when i install my front mount intercooler and i was wondering what to choose. looking on ebay at the comma ones you can see a few different ones Comma AQF Automatic Transmission Fluid Mineral 5L ATF5L COMMA AQF MINERAL AUTOMATIC TRANSMISSION FLUID 5 L LITRE - ATF5L Comma AQM Automatic Transmission Fluid 5Ltr Oils Transmission CCA COMMA ATF 5LT Comma AQ3 Automatic Transmission Fluid 5Ltr Oils Transmission CCA COMMA ATF 5LT im not too sure which type i need out of these or should i go with a different type? ill be flushing it through with the bucket method where it empties into an empty bucket from one hose and fill up from top Link to comment Share on other sites More sharing options...
bignum Posted March 30, 2013 Share Posted March 30, 2013 Any dextron 3 atf should be fine, see here, http://www.mkivsupra.net/vbb/showthread.php?56684-FAQ-Oil-Fluid-Interval-Capacity-Steering-Brake-Coolant-Diff-Engine Link to comment Share on other sites More sharing options...
ashbuster Posted March 30, 2013 Author Share Posted March 30, 2013 yeah mate but whats the difference between the aq3 ,aqf and the aqm Link to comment Share on other sites More sharing options...
bignum Posted March 30, 2013 Share Posted March 30, 2013 http://www.commaoil.co.uk/productsguide/index/6/29 i`d go with the aq3 Link to comment Share on other sites More sharing options...
ashbuster Posted March 30, 2013 Author Share Posted March 30, 2013 thanks bud Link to comment Share on other sites More sharing options...
garethr Posted March 31, 2013 Share Posted March 31, 2013 MVATF is the Dexron 3 equivalent. http://www.commaoil.co.uk/productsguide/view/6/180 Link to comment Share on other sites More sharing options...
ashbuster Posted March 31, 2013 Author Share Posted March 31, 2013 can power steering fluids be mixed? like for topping up ect... Link to comment Share on other sites More sharing options...
