T14PPA Posted March 27, 2013 Share Posted March 27, 2013 Car still not starting even after i removed new injectors and put oem injectors. Now im confused Quote Link to comment Share on other sites More sharing options...
Josh42 Posted March 27, 2013 Share Posted March 27, 2013 Can you hear the fuel pump priming? Do you have spark? Are the connections on your ECU pushed and bolted in correctly? Quote Link to comment Share on other sites More sharing options...
Kaan W Posted March 27, 2013 Share Posted March 27, 2013 Over fueled cylinders? Maybe crank the engine over with plugs out to clear the cylinders of all the petrol the previous injectors pumped in. Quote Link to comment Share on other sites More sharing options...
T14PPA Posted March 27, 2013 Author Share Posted March 27, 2013 There is spark and fuel pump is working. Ill try wat kaan said and hopefully hes right Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted March 27, 2013 Share Posted March 27, 2013 Also try cleaning the ends of the spark plugs up by heating with a blow lamp. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted March 27, 2013 Share Posted March 27, 2013 Plugs might be wrecked after all the cranking over ect Quote Link to comment Share on other sites More sharing options...
T14PPA Posted March 27, 2013 Author Share Posted March 27, 2013 All ive just tryed and nothing still Quote Link to comment Share on other sites More sharing options...
Kaan W Posted March 27, 2013 Share Posted March 27, 2013 Is there definately a spark? Quote Link to comment Share on other sites More sharing options...
T14PPA Posted March 27, 2013 Author Share Posted March 27, 2013 I checked one coil pack the other day and there was spark Quote Link to comment Share on other sites More sharing options...
Kaan W Posted March 27, 2013 Share Posted March 27, 2013 Im out of ideas mate, I hope someone comes along shortly with the answer to this problem. Quote Link to comment Share on other sites More sharing options...
T14PPA Posted March 27, 2013 Author Share Posted March 27, 2013 One coil pack gone but should still start Quote Link to comment Share on other sites More sharing options...
Guest smithy89 Posted April 1, 2013 Share Posted April 1, 2013 If you've got a spark, fuel and compression, you'll probably find it's flooded. Take the plugs out and leave it a few hours. Use a blowtorch to heat the old plugs up, or just replace them. Quote Link to comment Share on other sites More sharing options...
