s50b30 Posted March 26, 2013 Share Posted March 26, 2013 (edited) I bought a Project a while ago, and was going to install the oem fan today. But it hit the upper waterneck. Is it something im missing, or should it be some sort of spacer between the fan and the waterpump pulley? Its a supra mkiv btw, 2jzgte. its hit by just 1-2mm. Edited March 26, 2013 by s50b30 (see edit history) Link to comment Share on other sites More sharing options...
hodge Posted March 26, 2013 Share Posted March 26, 2013 The water neck or the top rad pipe. If its the waterneck that bolts to the head, I've a feeling your using an N/A fan. Link to comment Share on other sites More sharing options...
s50b30 Posted March 26, 2013 Author Share Posted March 26, 2013 top rad pipe. Yeah, I meant i read somewhere that ge fan is more inward. Link to comment Share on other sites More sharing options...
keron Posted March 26, 2013 Share Posted March 26, 2013 yep you will have a na fan then... the tt one is spaced out more to clear the tt top water neck Link to comment Share on other sites More sharing options...
s50b30 Posted March 27, 2013 Author Share Posted March 27, 2013 is it just the fan blades thats diffrent, or is it also the viscous coupling? Link to comment Share on other sites More sharing options...
Dnk Posted March 27, 2013 Share Posted March 27, 2013 If theres enough thread length on the 4 water pump bolts that the viscous fits too take the viscous inc fan off and space out the viscous with some washers of equal thickness Link to comment Share on other sites More sharing options...
