paulj1 Posted March 24, 2013 Share Posted March 24, 2013 I get water in the boot but can't seem to locate where its coming in is there a y common problems with this Quote Link to comment Share on other sites More sharing options...
jonc Posted March 24, 2013 Share Posted March 24, 2013 Boot seal is fairly common, electric aerial, bootlid spoiler bolt holes also fairly common, tailgate ram holes if someone has changed the rams and not replaced the small fibre washers. If you are really unlucky boot glass seal. In the past on other cars I have removed all the interior from the boot, closed it and lay inside whilst someone hoses down the outside. With everything removed you will soon see a dribble of water. Hope this helps Quote Link to comment Share on other sites More sharing options...
paulj1 Posted March 25, 2013 Author Share Posted March 25, 2013 Brilliant cheers jonc ill give it ago with hose pipe Quote Link to comment Share on other sites More sharing options...
