work euroline
jimmy1985
Hi guys,
I'm just looking at some work eurolines. Will these fitments below fit under standard arches or are they far to big:
Size:
19 x 9.5J offset +38mm with 95mm dish
19 x 12J offset -04mm with 115mm dish
Center bore 73mm
Thanks
James
In a word no.
The fronts you may get away with rolling the arches depending on the tyre sizes fitted, the rears would stick out way past the stock arches.
The following wheel sizes and offsets will sit just about flush with the stock wheel arches, you can then use this WHEEL OFFSET CALCULATOR to compare any wheels you are interested in.
Front: 9" +35
Rear: 10" +35
