Auto guru's please
wile e coyote
Hi guys I've had a issue with my auto box a couple of times now so if anybody can advise be great
The car drives fine and all gears work, but like yesterday I was driving for about 45 min on motorway usual speeds between 70 and 100 with traffic so box at usual temp.
Had a run with a couple of bikes which brought temp up to around 220 ( have a temp gauge fitted)
Now what happens is oil seems to come out off the top of the box , I think breather but not sure as cant see, this drips onto exhaust which then engages the smoke screen James Bond stile
I have an extra cooler fitted but between inter cooler and rad
I was considering getting my box refurb at srd later this year with another cooler.
So any ideas guys
Thanks darren
Slipping clutch packs or torque converter can also cause high temps, but that will cause driving issues and turn the colour of the oil brown with a strong smell of burnt oil.
EDIT: make sure the oil pipes are not kinked and causing a restriction in the flow as you have a additional cooler plumbed in.
Edited by absz (see edit history)
