2pk Paint does it need to be baked?
safcdixon
As title really does 2pk paint "NEED" to be baked or does that just aid the drying process?
Am I right in thinking its a 2parts paint 1part hardener and a % of thinnners,
another thing a mate said I wouldn't need hardener with the paint just with the lacquer is this wrong? im thinking its wrong but thought I would ask to be sure,
any help would be great :)
if its a base-coat( then you will need thinner's in the colour and then Hardener and a % of thinners in the clearcoat, if its a solid(full gloss without clear-coat) then you will need hardener in the paint.
You don't need to bake it, instead use an Air-dry hardener, these will still need a warm workshop/garage to dry in, typically around 20deg C (ideally)
Its just a basecoat so I don't need hardener in the paint? or I do? I cant tell by the way you've wrote that out :D
cheers for the help
cheers for the help
No hardener in Base-coat just thinners, then clear-coat over the top of it. you paint supplier should supply a info sheet with the paint :)
I never received a sheet with the paint mate, I think il pop in and see him tomorrow after work just to confirm, cheers for the help :)
