Need of Pressure tank for single?
teddan
The pressured air in the pressure tank is used to operate the actuators for the sequential system, it is not needed if you are doing a single turbo install.
As above, the pressure tank is used to control the stock twins. If your going single bin it :)
My single aristo ran fine with the piping for it disconnected. Paul whiffin did say it might be needed to assist the idle of the car. But mine ran fine without it. Hopefully someone will be along with a definative answer though.
You are thinking of the power steering pressure valve?
