MrRalphMan Posted March 22, 2013 Share Posted March 22, 2013 So currently my bonnet will not secure properly. At first it would not latch down at all and keep popping up when close. A blast of WD40 on both the catches had made it better, but not secure. Now it will stay down, but if i put my hands under the loo of the bonnet I can pop it open. Testing the two catches, one will clock down when pressed down with a screw driver, the other doesn't. Would that be a cable broken between the splitter and the catch or something else? How easy is it to remove the catches? Many thanks Paul Quote Link to comment Share on other sites More sharing options...
peter richards Posted March 22, 2013 Share Posted March 22, 2013 the drivers side on mine is a bit iffy , the lever inside on mine doesnt go back flush when its not shut prperly , i oil and WD 40 it , seems to help for a while . Quote Link to comment Share on other sites More sharing options...
MrRalphMan Posted March 22, 2013 Author Share Posted March 22, 2013 Hey Peter, Did you take it out for that or just lube it in place? Quote Link to comment Share on other sites More sharing options...
