STAR T67R ~ 1.8 bar ~ 755bhp ~ 596ftlbs at the hubs
Carbon_Bullet
So the story begins ......
I've owned supra's for nearly 8 years now, the last 6 months I've been supraless an it killed me, so after breaking my last car I have average amount of money to fund a decent build,
So my plan is to source a decent single turbo 6 speed and an aerotop shell, well luckily enough in this last week both cars popped up on the forum so I have 90% of what I need to start the build
Stripping back the aero to its bare shell, complete respray and under seal, subframes/suspension arms/diff/gearbox getting a fresh coat too, every bolt is going to be replaced/refreshed, all rubber bushes replaced, every piece of interior will have an overhaul too, the whole car will be brand new.
The new car once built has been given the nickname STAR T67R,
STAR standing for Single Turbo Aerotop Ridox and the T67R being the turbo fitted
2 cars I have
Description
STAR T67R Description:
Built by SRD
1995 MKIV Toyota Supra Aerotop 6sp
1.8 bar - 765bhp - 596ftlbs at the hubs
Engine:
JE pistons
Carillo Rods
Clevite main and big end bearings
NGK Grade 9 racing plugs
H11 Head Studs
ARP Main Studs
SRD stage 3 race head
Brian Crower valve springs & titanium retainers
HKS Cam pulleys
HKS 264 Cams
GREDDY Plenum
GREDDY Plenum pipe kit
Nissan Infinity Q45 Throttle body 90mm
Magnetic sump plug
Larger Lexus Oil Filter
PHR idler pulley
SRD Billet TBTB
Kevlar Gates racing timing belt
HKS SSQV 4 dump valve
SRD aircon delete bracket
New Toyota OEM Complete new gasket set
New Toyota OEM Water Pump
New Toyota OEM Oil Pump
New Toyota Timing belt tensioner
New Toyota OEM Timing Belt Idler Wheel
Custom HKS purple cam covers
Custom HKS purple caps & covers
Carbon Engine Cover
SRD Custom cam breather hose set -12 AN
Custom alloy overflow tank (hidden)
TRD Thermostat
Fluidampr crank pulley
Turbocharger & Induction:
Precision T6766 (Rated to 930bhp)
HKS Racing BOV
Whifbitz Tubular T4 Manifold
SRD 4" Mid/Down pipe
New Toyota OEM exhaust manifold nuts and studs
SRD Billet Water Inlet Pipe
Water output pipe Smoothed off and Polished
4'' Polished Intake Pipe
4'' K&N Filter
Braided Oil Feed and Return Lines
Twin 40mm Turbosmart Waistgate
DEI T4 Titanium heat shield
Fuel, Tuning & ECU:
Syvecs S6 ECU, with adjustable boost setting, 1.2,.1.4,1.6,1.8 BAR
Syvecs Traction Control
Sevens Bluetooth
Syvecs loom adapter
Syvecs Flex fuel sensor
Syvecs knock sensor
3.5 Bar AEM Map Sensor
HKS Style Fuel Rail
ASNU 1100cc Injectors
SRD E85 fuel Lines
Twin walbro 455 pump
AEM wideband Gauge
Flex fuel sensor (ethanol)
Fuel lab FRP
Cooling:
4'' ToyoSports FMIC with Custom Piping
Koyo Radiator
HKS Oil Cooler
Blitz 1.4bar Rad Cap
SRD Twin Fan Kit
Exhaust:
Whifbitz 4" Exhaust, with a 4" Full System leading to Turbo.
Custom decat
Drivetrain:
V160 6 Speed Manual Getrag Gearbox
Whifbitz Solid Gearshift Bushes
New OEM Toyota Gear Selector Seal
Stock Jspec Diff B03B
Whifbitz Solid Selector Bushes
Carbonetics Double Carbon Clutch
Suspension, Wheels, Tires & Brakes:
K-Sport big brake conversion 6/4 Pot
K-Sport 356MM Disks
Porterfield RS4 pads
Braided Brake Lines
Carbon Wed SA-70 Wheels 9x18 and 10x18 +32 offset
Neo Chrome Race Wheel Nuts
Michelin Super Sport Cup 2 Tyres 295/35/18 Rear, 245/40/18 Front
BC Racing Adjustable Coilovers
Cusco Front and Rear Strut Braces
Complete rear subframe adjustable arms
Interior & ICE:
Custom STAR dials with blue needles(red flicker on redline)
Fully flocked interior in black
VIBE front and rear speakers
Defi Control Unit, Water Temp, Boost, Oil Temp, Ext Temp, Oil Pressure, Speedometer, shift light
AEM Wideband Gauge
LED dash instruments
Carbon dash with chrome rings
Carbon Fibre Glove Box Gauge Holder
Carbon centre box cover
Double Pillar Gauge Holder
OEM Black carpet
OEM Black Head lining and UK Visors
Recaro Seats, with Bride Rails
4 point Harness
Rear seats removed
White Cusco half roll cage
Exterior:
Full Ridox Body Kit.
Carbon Auto Shine Front Splitter
Carbon Auto Shine Air Diverters
Carbon Auto Shine Rear Diffuser
Carbon Canards x4
Carbon Top Secret Bonnet
Carbon Top Secret Spoiler
Carbon Squarecraft Door Mirrors
De-Wipered
De-Ariel
Facelift Headlights
Carbon Facelift LED rear taillights
6000k Knight Racer HID's
Other MODS:
Custom engine bay covers SRD type 2
Front Licence plate flipper
Laser line alarm system
Latest picture of the new car
Edited by Carbon_Bullet (see edit history)
  • Replies 700
  • 3 weeks later...
