lewysdanny Posted March 21, 2013 Share Posted March 21, 2013 Out in my 95 tt BPU today and under a quick blast of boost started to mis-fire. This only lasted 5-10 secs then back to normal. It only went back to normal when i took my foot off the throttle. Has anyone got any ideas.?? Tim ( lewysdanny ) Quote Link to comment Share on other sites More sharing options...
listy Posted March 21, 2013 Share Posted March 21, 2013 Sticky vsv? Maybe IACV. I have a similar problem now Tim. Does it sound similar to this? http://www.mkivsupra.net/vbb/showthread.php?286925-Kangaroo-hopping Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted March 21, 2013 Share Posted March 21, 2013 If its a misfire its normally igntion. Take a look at your coil pack connectors as they can break up with old age. If they are ok next place to look is your spark plugs, if they are good then its new coil pack time. Paul Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted March 21, 2013 Share Posted March 21, 2013 If its a misfire its normally igntion. Take a look at your coil pack connectors as they can break up with old age. If they are ok next place to look is your spark plugs, if they are good then its new coil pack time. Paul Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 21, 2013 Share Posted March 21, 2013 1st stop for missfires, as Paul said is coil packs and clips. Quote Link to comment Share on other sites More sharing options...
TT Paul Posted March 22, 2013 Share Posted March 22, 2013 mine dose it new plugs, coilpacks and plugs, where would that leave you Quote Link to comment Share on other sites More sharing options...
listy Posted March 22, 2013 Share Posted March 22, 2013 mine dose it new plugs, coilpacks and plugs, where would that leave you Check my thread in my previous post dude. I'm doing my plugs and coil pack clips next week. Quote Link to comment Share on other sites More sharing options...
downimpact Posted March 22, 2013 Share Posted March 22, 2013 Terra clean Quote Link to comment Share on other sites More sharing options...
listy Posted March 22, 2013 Share Posted March 22, 2013 Terra clean Mine has the same symptoms but no Terraclean here! Quote Link to comment Share on other sites More sharing options...
Guest Goss Posted March 23, 2013 Share Posted March 23, 2013 mine would misfire under boost because my plugs had too much gap. I had to switch to a .032" and 1 heat state cooler. Quote Link to comment Share on other sites More sharing options...
TT Paul Posted March 23, 2013 Share Posted March 23, 2013 my bad its only on warm up now, think its the temp sensor for ecu Quote Link to comment Share on other sites More sharing options...
lewysdanny Posted March 23, 2013 Author Share Posted March 23, 2013 Well guys i suppose its a case of elimination. Ive just changed the discs and pads on off side today. Tomorrow will be the near side , then i,ll change the plugs. If its not plugs i,ll go for coil clips. If alls not well, then i,m looking at major bucks to change the coil pack itself. Quote Link to comment Share on other sites More sharing options...
listy Posted March 23, 2013 Share Posted March 23, 2013 Well guys i suppose its a case of elimination. Ive just changed the discs and pads on off side today. Tomorrow will be the near side , then i,ll change the plugs. If its not plugs i,ll go for coil clips. If alls not well, then i,m looking at major bucks to change the coil pack itself. That's my plan mate. Sorry I've not called, I've been pretty busy lately. I'm going to be doing my plugs etc late one night this week, as its the only spare time I've got to do it. If it was in a few weeks time, would have had more time to meet up and get them both done Quote Link to comment Share on other sites More sharing options...
lewysdanny Posted March 23, 2013 Author Share Posted March 23, 2013 Yeah no probs mate . I,ll catch up later Quote Link to comment Share on other sites More sharing options...
TT Paul Posted March 23, 2013 Share Posted March 23, 2013 if its not your plugs or clips just try one pack at a time as may only be one of them may save some money.. Quote Link to comment Share on other sites More sharing options...
lewysdanny Posted March 23, 2013 Author Share Posted March 23, 2013 Thanks for that Paul , i,ll bare it in mind Quote Link to comment Share on other sites More sharing options...
