JohnK Posted August 16, 2005 Share Posted August 16, 2005 I am in the process of changing to a cast manifold from one of the boostlogic adaptor manifolds. All on the tightest budget imaginable. Luckily I can do / get done 99% of the work myself. Not a great deal of progress at the moment as i've just started but you can follow my progress HERE Just follow the link to cast manifold. I should add, this is not a case of buying things and me bolting them on, there will be a fair bit of fabrication and modification going into this. Link to comment Share on other sites More sharing options...
JohnK Posted August 16, 2005 Author Share Posted August 16, 2005 your comments welcome Link to comment Share on other sites More sharing options...
michael Posted August 16, 2005 Share Posted August 16, 2005 No comments as yet but I want to follow your progress, is that one of Arnout's manifolds on there? I can see myself going a similar route having seen eyefi's setup, looks like a quality chunk. Link to comment Share on other sites More sharing options...
Whitelightning Posted August 16, 2005 Share Posted August 16, 2005 Good luck m8 - we need to spin round Southampton in our Supes whilst the sun is out so get a peg on ! Link to comment Share on other sites More sharing options...
JohnK Posted August 16, 2005 Author Share Posted August 16, 2005 It is one of Arnout's and the quality is good. The one comment I have is that the holes dont line up 100% with the studs on my head, dont get me wrong it slides over them fine, but only some of the holes are spotfaced and where the stud isnt quite on center I will have to use an extra washer with the collared nuts. And as I said not all are spot faced. Link to comment Share on other sites More sharing options...
Jake Posted August 16, 2005 Share Posted August 16, 2005 What does spot faced mean, John? Link to comment Share on other sites More sharing options...
eyefi Posted August 16, 2005 Share Posted August 16, 2005 eyup john, the wastegate doesn't fit upto the manifoild, there is a connecter pipe to fit between. the hks 50mm will fit angled forward to the manifold and there is room to dump to atmosphere easily (if that's what you want to do). as for the downpipe, no easy options but fabricating. have a look here for some pics http://www.mkivsupra.net/vbb/showthread.php?t=40693 Link to comment Share on other sites More sharing options...
JohnK Posted August 16, 2005 Author Share Posted August 16, 2005 The hole on the right is spot faced, the one on the left not. Spot facing ensures that the nut is bearing down on a surface parallel to the mating face. Link to comment Share on other sites More sharing options...
JohnK Posted August 16, 2005 Author Share Posted August 16, 2005 Eyefi - thanks for the pointer. I already have an adaptor in progress to fit the wastegate Link to comment Share on other sites More sharing options...
JohnK Posted August 16, 2005 Author Share Posted August 16, 2005 Just to add - I am trying to reuse as much as possible of the parts I already have. Link to comment Share on other sites More sharing options...
Jake Posted August 16, 2005 Share Posted August 16, 2005 JohnK said: The hole on the right is spot faced, the one on the left not. Spot facing ensures that the nut is bearing down on a surface parallel to the mating face. Ah, gotcha now. Thanks Link to comment Share on other sites More sharing options...
arnout Posted August 17, 2005 Share Posted August 17, 2005 The holes in the manifold are 'wrong' to allow the exhaust manifold to expand! Link to comment Share on other sites More sharing options...
JohnK Posted August 17, 2005 Author Share Posted August 17, 2005 I'm not criticising, its just my observations. Also I didn’t say anything was "wrong". Would it not be a good idea to machine a flat area on the back of all holes instead of spot facing just some as at the moment if the collar of the nut were to sit in the spot face it would not allow any movement for expansion. Link to comment Share on other sites More sharing options...
JohnK Posted August 17, 2005 Author Share Posted August 17, 2005 Arnout, I forgot to ask in my last post, where would you suggest to mount my EGT gauge? no.1, no6 or near the center by the turbo inlet? Link to comment Share on other sites More sharing options...
eyefi Posted August 17, 2005 Share Posted August 17, 2005 john, i was monitoring no1 cyl previously so i continued to do that with this manifold, for comparison purposes. you want that probe as close as possible to the valve to get the gas temp as accurate as possible. i dont think the centre is the best place. Link to comment Share on other sites More sharing options...
JohnK Posted August 17, 2005 Author Share Posted August 17, 2005 Eyefi - thats where I had it before as well. I was thinking it should remain there, Ive had it both at no1 and no6 and didnt notice much different between the 2. I was hopeing to get Arnouts experienced view on this. Link to comment Share on other sites More sharing options...
arnout Posted August 17, 2005 Share Posted August 17, 2005 I normally drill & tap in the exhaust housing (inlet flange that bolts to the manifold). Link to comment Share on other sites More sharing options...
JohnK Posted August 17, 2005 Author Share Posted August 17, 2005 Added 3 composite pics of the turbo and manifold and where they are before modification. Arnout - Thanks Link to comment Share on other sites More sharing options...
JohnK Posted August 22, 2005 Author Share Posted August 22, 2005 Updated a little more. Link to comment Share on other sites More sharing options...
JohnK Posted September 5, 2005 Author Share Posted September 5, 2005 yet another small update, been off work so little progress Link to comment Share on other sites More sharing options...
michael Posted September 5, 2005 Share Posted September 5, 2005 Great stuff! Nice to see you are nearly there too.... Link to comment Share on other sites More sharing options...
Guest GadTek Posted September 6, 2005 Share Posted September 6, 2005 That is a tiny little turbo! Link to comment Share on other sites More sharing options...
JohnK Posted September 6, 2005 Author Share Posted September 6, 2005 Its a Boostlogic T61, good for over 500bhp without too much lag. Link to comment Share on other sites More sharing options...
JohnK Posted September 13, 2005 Author Share Posted September 13, 2005 Ok I have finally completed this conversion. details on the website. Link to comment Share on other sites More sharing options...
Alex Posted September 13, 2005 Share Posted September 13, 2005 How does it feel l then (seat of the pants) vs the old setup? Link to comment Share on other sites More sharing options...
