Guest sl1d3r Posted March 18, 2013 Share Posted March 18, 2013 Hi guys checked my ignition timing the other day and had some funny results got a brand new gunson advanced timing light blocked the pins in the dignostic port cliped on to green wire started her up and got a reading of 26deg before tdc now i know the car should be 10deg but it was ticking over fine and runs fine !!! so either my timing gun is shot or something isnt right just wondering if anyone has any suggetions ?? on and how do you adjust the timing on the 2jzgte ??? your probly think this is a dumb question but i am new to the mkiv supra cheers Link to comment Share on other sites More sharing options...
Kaan W Posted March 18, 2013 Share Posted March 18, 2013 Hi and welcome to the club! Good to see another Kent member. I dont know the answer but im sure someone will be along soon to help Link to comment Share on other sites More sharing options...
Guest sl1d3r Posted March 18, 2013 Share Posted March 18, 2013 cheers allways wanted one and now i do woop lol cant wait to start getting my hands greasy lol Link to comment Share on other sites More sharing options...
pedrosixfour Posted March 18, 2013 Share Posted March 18, 2013 Ask this chap, maybe he got to the bottom of it. http://www.mkivsupra.net/vbb/showthread.php?285640-2jz-tt-ignition-timing&highlight=gunson. Link to comment Share on other sites More sharing options...
Swampy442 Posted March 18, 2013 Share Posted March 18, 2013 You cant adjust the timing on the 2JZ GTE, its set by the ECU. And, like I asked on the other thread, why did you need to check it anyway? Link to comment Share on other sites More sharing options...
pedrosixfour Posted March 18, 2013 Share Posted March 18, 2013 Swampy442 said: You cant adjust the timing on the 2JZ GTE, its set by the ECU. And, like I asked on the other thread, why did you need to check it anyway? That was a different member Swampy, or so it would seem. Link to comment Share on other sites More sharing options...
Swampy442 Posted March 18, 2013 Share Posted March 18, 2013 It was, but the same question still stands Link to comment Share on other sites More sharing options...
Andy Blyth Posted March 18, 2013 Share Posted March 18, 2013 Here's a little trick of the trade: Don't clip a timing light around the green loop of wire in the igniter connector; it's just the designated decoy. You can use a normal timing light just fine by clipping it around both of the wires going to the coilpack of cylinder one. The arrow on the pickup points towards the sparkplug, just like on a HT lead. It does mean taking the spark plug cover off, which is a pain when you just want to check the timing. Link to comment Share on other sites More sharing options...
Guest sl1d3r Posted March 23, 2013 Share Posted March 23, 2013 Swampy442 said: You cant adjust the timing on the 2JZ GTE, its set by the ECU. And, like I asked on the other thread, why did you need to check it anyway? Hi mate i have allways checked timing on all of my cars as sometimes it can throw out a little only checked this one as i am doin a lil over haul you know new oil filter plugs all the old usauls so while i am there quick check of timing and adjust if needed lol Link to comment Share on other sites More sharing options...
Guest sl1d3r Posted March 23, 2013 Share Posted March 23, 2013 Andy Blyth said: Here's a little trick of the trade: Don't clip a timing light around the green loop of wire in the igniter connector; it's just the designated decoy. You can use a normal timing light just fine by clipping it around both of the wires going to the coilpack of cylinder one. The arrow on the pickup points towards the sparkplug, just like on a HT lead. It does mean taking the spark plug cover off, which is a pain when you just want to check the timing. Ok mate thanks ill have a little go of that today and see if i get a differant reading and ill keep you posted if nothing changes cheers Link to comment Share on other sites More sharing options...
Guest sl1d3r Posted March 23, 2013 Share Posted March 23, 2013 Swampy442 said: You cant adjust the timing on the 2JZ GTE, its set by the ECU. And, like I asked on the other thread, why did you need to check it anyway? This i havent heard but if the timing is set to 10tdc on ecu but out at the car surly you need to marry the two up ?? Link to comment Share on other sites More sharing options...
absz Posted March 23, 2013 Share Posted March 23, 2013 Silly question but has your timing gun got buttons to calibrate it, normally run the engine adjust gun so it reads zero then you press the trigger to get the correct reading. Link to comment Share on other sites More sharing options...
