welshbuddy Posted March 16, 2013 Share Posted March 16, 2013 can some one give me a step by step guide to do this, as im in the process of doing it, im removing engine and box by dropping it. need it asap really cheers,daz. Quote Link to comment Share on other sites More sharing options...
listy Posted March 16, 2013 Share Posted March 16, 2013 I can help a bit. Support the engine with a crane. The front cross bar needs to come off first. Iirc there are 3 bolts either side. Plus a small support bar either side (one bolt each end, remove these first). Once that is off, then the main subframe can come off, but I can't remember where all the bolts are Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted March 16, 2013 Author Share Posted March 16, 2013 lol cheers buddy, ive been researching everywhere for some photos, i know steering rack needs to come off, then the bolts either side. im going to put a jack underneath and drop it after in one, as im cutting the front of the car out so i can just pull engine and box out together ya see Quote Link to comment Share on other sites More sharing options...
supra joe Posted March 16, 2013 Share Posted March 16, 2013 Interested in this, wouldn't mind powder coating the parts and subframe. Quote Link to comment Share on other sites More sharing options...
Guest BradD Posted March 16, 2013 Share Posted March 16, 2013 (edited) we did this with a Lexus SC400 to pull the engine and trans out, they both have same subframes. Supported the engine and box on trolleys I think there were two bolts at the back of the lower arms and one at the front, 4 on the actual subframe and 4 to undo the ARB Also the steering column linkage needs to be undone then rolled everything forward..... It wasn't too difficult, took a couple hours, can't imagine there will be much difference, if any, for the supra. Edited March 16, 2013 by BradD (see edit history) Quote Link to comment Share on other sites More sharing options...
