peter richards Posted March 16, 2013 Share Posted March 16, 2013 ok guys , got an ally radiator and oil cooler coming this week from dude . is this something i can do ?? im asking myself and you guys . if it is can you give me a run through of first getting the old one out (procedure). and then fitting the new one and the oil cooler . john said hed run through it with me , but i kind of want to try and familiarise myself a bit first , so at least i know what im looking at when i do it . thanks peter Quote Link to comment Share on other sites More sharing options...
Al Massey Posted March 16, 2013 Share Posted March 16, 2013 The radiator is easy. Drain it from the bottom. Undo both coolant hoses upper and lower. Remove the top clamps and lift out. If you fan cowel is still on remove that first. And then reverse. I'm not too sure on the oil cooler as it depends where you mount it. But I'm pretty sure you need to tap in to the oil feed and oil return. Quote Link to comment Share on other sites More sharing options...
