Lower water neck problem
Andrew K
As you can see from the picture its a bit tight for space to get a hose onto the lower water neck pipe because of the turbo piping, I know you can get after market ones to sort this problem out but was wondering if you can use one from
An N/A as I happen to have one laying around I could use. If I can will it be ok to use?
https://jza80.mkivsupra.net/imports/2013/03/354.jpg[/img]"]image
https://jza80.mkivsupra.net/imports/2013/03/355.jpg[/img]"]image
This is the N/A lower water neck I was wondering if its ok to use?
https://jza80.mkivsupra.net/imports/2013/03/356.jpg[/img]"]image
Use an N/A lower neck. There perfect for large frame turbos. I have 1 fitted to mine with an 80mm T6 setup. You'll need to drill the holes out a little bigger but it's no big deal. I just did mine with a hand drill. There's pics in my project thread somewhere.
