Guest supraman006 Posted March 16, 2013 Share Posted March 16, 2013 just want to find out if the w58 would be ok for everyday use behind my 2jzgte +- 350 whp not going to be dragging it or launching it at 6000 rpm.thanks Quote Link to comment Share on other sites More sharing options...
listy Posted March 16, 2013 Share Posted March 16, 2013 Will be fine. I run a W58 at BPU (circa 400bhp) no problems. Just avoid hard shifts and harsh down shifts. Quote Link to comment Share on other sites More sharing options...
Supra Gaz Posted March 16, 2013 Share Posted March 16, 2013 I know of two people doing it, they drive quite hard at times, it's been a few years for both and all is well. Quote Link to comment Share on other sites More sharing options...
listy Posted March 16, 2013 Share Posted March 16, 2013 To be fair, mine does occasionally take some punishment Quote Link to comment Share on other sites More sharing options...
Guest supraman006 Posted March 16, 2013 Share Posted March 16, 2013 Ok cool because iv just got myself a jdm 2jzgte looking to do the swap next month and heard many good and bad storys so just thought I would ask people who have done it. Anyone got some good info on a clutch setup I hear stock clutch could handel 300 bhp is this true? Only going to be running .6 bar (10psi) to start off isn't there another toyota clutch plate I could match up that has more clamping force?what are u guys useing on your w58's? Quote Link to comment Share on other sites More sharing options...
Supra Gaz Posted March 16, 2013 Share Posted March 16, 2013 Upgrade the clutch dude, and fly while your at it. Whifbitz is the place to go. You will rape the stock clutch in seconds. Quote Link to comment Share on other sites More sharing options...
Guest supraman006 Posted March 16, 2013 Share Posted March 16, 2013 Ok I will do that thanks Quote Link to comment Share on other sites More sharing options...
listy Posted March 16, 2013 Share Posted March 16, 2013 I have a 6 puck stage 4 competition clutch and stock fly wheel. Are you going auto to manual? If so, I wouldn't bother with a w58. Either go with a R154 box or a getrag 6. Quote Link to comment Share on other sites More sharing options...
Guest supraman006 Posted March 16, 2013 Share Posted March 16, 2013 Well all I have is my w58 at the moment an where I'm from can't really get those gearboxes so ill use what iv got for now just need a decent w58 clutch setup. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 20, 2013 Share Posted March 20, 2013 If you want a marginal gear box to survive excess torque run a sprung hub clutch with JUST enough clamping pressure not to slip under full torque, but no more. Puck clutches, multi plate clutches, and clutches with no sprung hub will make failure more likely. As will driving like in some extreme video game Shock loads are what USUALLY kill them. Quote Link to comment Share on other sites More sharing options...
Noz Posted March 20, 2013 Share Posted March 20, 2013 at the very least buy NEW budget components. clutch is a MUST is it worth even risking? some people wont even get 2 miles on a stock clutch. Quote Link to comment Share on other sites More sharing options...
Guest supraman006 Posted April 1, 2013 Share Posted April 1, 2013 will do that cheers Quote Link to comment Share on other sites More sharing options...
SupraHW Posted April 2, 2013 Share Posted April 2, 2013 I've done +- 3k KM on it since my swap ( GTE VVTi ) with an F1 stage 4 clutch... Doing good so far! Dont abuse it and you'll be fine Quote Link to comment Share on other sites More sharing options...
James Posted April 2, 2013 Share Posted April 2, 2013 I've had my W58 2JZ-GTE setup since July 2009 and have had no transmission issues to date (touch wood). Quote Link to comment Share on other sites More sharing options...
Dan_Turism0 Posted April 2, 2013 Share Posted April 2, 2013 i think a lot is luck of the draw, i know someone who went through 3 w58's on a 365bhp NA-T setup Quote Link to comment Share on other sites More sharing options...
SupraHW Posted April 2, 2013 Share Posted April 2, 2013 i think a lot is luck of the draw, i know someone who went through 3 w58's on a 365bhp NA-T setup Think it has more to do with how you use these w58's... Like James mentioned he is driving it for a while now, I'm , a couple of friends of my are running it as well, no problems there! Hard pulls & crazy shifts will most likely kill it... Quote Link to comment Share on other sites More sharing options...
Noz Posted April 3, 2013 Share Posted April 3, 2013 How they are serviced makes a difference also. It's hard to know the history. 3 boxes is just unlucky. I've been smashing mine into third gear spins lately and seems to be holding ok. Quote Link to comment Share on other sites More sharing options...
dr_jekyll Posted April 3, 2013 Share Posted April 3, 2013 i broke a few but that was all hard track abuse Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted April 3, 2013 Share Posted April 3, 2013 Think it has more to do with how you use these w58's... Like James mentioned he is driving it for a while now, I'm , a couple of friends of my are running it as well, no problems there! Hard pulls & crazy shifts will most likely kill it... What's the point in doing the conversion if you can't drive it hard? might as well stick with a TT auto box if you're on a budget, they're much stronger. Quote Link to comment Share on other sites More sharing options...
James Posted April 3, 2013 Share Posted April 3, 2013 Mine is driven hard (enough) daily. I'm not sure how it has lasted but - until it stops lasting - I won't complain. Quote Link to comment Share on other sites More sharing options...
Guest supraman006 Posted April 3, 2013 Share Posted April 3, 2013 Well my car will mainly be for the street so hopefully the poor old W58 will last. Quote Link to comment Share on other sites More sharing options...
adarmo Posted April 5, 2013 Share Posted April 5, 2013 If you want a marginal gear box to survive excess torque run a sprung hub clutch with JUST enough clamping pressure not to slip under full torque, but no more. Puck clutches, multi plate clutches, and clutches with no sprung hub will make failure more likely. ^^^ This is very good advice Quote Link to comment Share on other sites More sharing options...
listy Posted April 5, 2013 Share Posted April 5, 2013 I run a 6 puck clutch with my w58 at BPU. Not a problem yet and I've been running this way over a year now. Quote Link to comment Share on other sites More sharing options...
st3ven1 Posted April 5, 2013 Share Posted April 5, 2013 What's the point in doing the conversion if you can't drive it hard? might as well stick with a TT auto box if you're on a budget, they're much stronger. This. What's the point if you can't drive it hard, drag race, track it, drift it etc I wouldn't want to have a car where I would be worried about the gear box lasting each time I drive it. The other think to mention is people's definitions of being driven hard. I get the feeling some who drive it "hard" would consider others(probably including myself) to be damn right abusive when driving a car hard. It's all relative to what you are used too. Quote Link to comment Share on other sites More sharing options...
