mitchell Posted March 15, 2013 Share Posted March 15, 2013 Hi there, I've taken my Supra in to have the heater matrix replaced and the mechanic has called saying that the air con unit has to be removed in order for him to get to the matrix and replace. He says that he would have to get someone in to remove the air con unit and re-gas which would cost a lot more. Having quickly scrolled through the matrix replacement guides on here and seen that it was too big a job for me, I cant remember seeing anything about factoring in the air con removal and re-gasing. Is there soemone with experience of this that can confirm if the air con needs to be removed and regassed or is there an alternative way? Help would be very much appreciated as im without car! Thanks all! Quote Link to comment Share on other sites More sharing options...
James Posted March 15, 2013 Share Posted March 15, 2013 The 2 air con pipes need to be undone to get the plate moved for removal of the heater matrix. You can't get the heater box out without these AC pipes popped out of the socket they are in. You should NOT remove these pipes if there is still air con gas in the system. The whole air con arrangement doesn't need to be removed, just the 2 pipes to be disconnected to get the retaining plate for the heater box free. Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 15, 2013 Share Posted March 15, 2013 (edited) Just get an aircon regas place to empty the system then your mechanic can do the matrix then just get it refilled, its not that expensive to do Should be mobile ones in your area if you search google, i'd have thought £50 to empty and regas the system, some are more some less Edited March 15, 2013 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
mellonman Posted March 15, 2013 Share Posted March 15, 2013 I managed to undo all bolts to the aircon and pipe and surounding bolts and pried mine out the way all connected, but no way a garrage will do that Quote Link to comment Share on other sites More sharing options...
