Guest geth792 Posted March 14, 2013 Share Posted March 14, 2013 Anyone know?? Think I've got a slight leak from it??? Link to comment Share on other sites More sharing options...
Guest Budz86 Posted March 14, 2013 Share Posted March 14, 2013 Think its a vapour pipe from the crank case that stops too much pressure building up. I'm probably wrong though. Link to comment Share on other sites More sharing options...
David P Posted March 14, 2013 Share Posted March 14, 2013 If it's under the passenger floor it's the air-con drip pipe. If it's under the passenger wing it's the charcoal filter drip pipe. Link to comment Share on other sites More sharing options...
Swampy442 Posted March 15, 2013 Share Posted March 15, 2013 Or if its at the front its the radiator drain plug. In short, more info required. Link to comment Share on other sites More sharing options...
Kaan W Posted March 15, 2013 Share Posted March 15, 2013 Or it could be from the battery tray Link to comment Share on other sites More sharing options...
David P Posted March 15, 2013 Share Posted March 15, 2013 That equates to as many little drips under it as you could get in it. Link to comment Share on other sites More sharing options...
The Raven Posted March 15, 2013 Share Posted March 15, 2013 Its the aircon pipe Link to comment Share on other sites More sharing options...
Guest geth792 Posted March 15, 2013 Share Posted March 15, 2013 Well it looks like its coming from the battery tray and sticks down about 4 inches under the car???? What could be leaking from there?? Strange!!! Link to comment Share on other sites More sharing options...
Kaan W Posted March 15, 2013 Share Posted March 15, 2013 Well it looks like its coming from the battery tray and sticks down about 4 inches under the car???? What could be leaking from there?? Strange!!! Cha ching! I was right for once What do I win? Link to comment Share on other sites More sharing options...
Guest geth792 Posted March 15, 2013 Share Posted March 15, 2013 So what can leak from it??? Link to comment Share on other sites More sharing options...
David P Posted March 15, 2013 Share Posted March 15, 2013 What comes out, is what goes in. Be brave and open the bonnet and your eyes at the same time. Link to comment Share on other sites More sharing options...
Guest geth792 Posted March 15, 2013 Share Posted March 15, 2013 I have looked every level seems to be ok!! If its a battery tray must be the battery then!! Link to comment Share on other sites More sharing options...
David P Posted March 15, 2013 Share Posted March 15, 2013 Stick your finger in it, if it's battery acid you'll soon find out. I'd guess it more likely to be water that finds it's way to the battery tray from the bonnet/wing gutter. Link to comment Share on other sites More sharing options...
hackin_n_bashin Posted March 15, 2013 Share Posted March 15, 2013 Well you learn something new every day. I thought that when you drove over a puddle and pressed the red button it filled the washer bottle up. Link to comment Share on other sites More sharing options...
David P Posted March 15, 2013 Share Posted March 15, 2013 Well you learn something new every day. I thought that when you drove over a puddle and pressed the red button it filled the washer bottle up. Only if you have the Fillitup geometry settings. Link to comment Share on other sites More sharing options...
Mugello Posted March 15, 2013 Share Posted March 15, 2013 Stick your finger in it, if it's battery acid you'll soon find out. I'd guess it more likely to be water that finds it's way to the battery tray from the bonnet/wing gutter. this Link to comment Share on other sites More sharing options...
Stevo Posted March 15, 2013 Share Posted March 15, 2013 Well you learn something new every day. I thought that when you drove over a puddle and pressed the red button it filled the washer bottle up. Link to comment Share on other sites More sharing options...
RobUK Posted March 15, 2013 Share Posted March 15, 2013 This is bordering on the "how do I open my boot thread" !! Really! Link to comment Share on other sites More sharing options...
bambisdad Posted March 15, 2013 Share Posted March 15, 2013 Wow the Red Button. We haven't had mention of that for ages. Link to comment Share on other sites More sharing options...
Kaan W Posted March 15, 2013 Share Posted March 15, 2013 Wow the Red Button. We haven't had mention of that for ages. What red button? Why dont I have one... Link to comment Share on other sites More sharing options...
RobUK Posted March 15, 2013 Share Posted March 15, 2013 What red button? Why dont I have one... I am guessing you have a manual... It's only on an auto. Link to comment Share on other sites More sharing options...
David P Posted March 15, 2013 Share Posted March 15, 2013 I am guessing you have a manual... It's only on an auto. Not in a U.K. spec auto RobUK. Link to comment Share on other sites More sharing options...
Kaan W Posted March 15, 2013 Share Posted March 15, 2013 I have a UK spec Auto, where is this so called red button and whats it for? Apart from sucking up puddles. Link to comment Share on other sites More sharing options...
David P Posted March 15, 2013 Share Posted March 15, 2013 Not in a U.K. spec auto RobUK. I have a UK spec Auto, where is this so called red button and whats it for? Apart from sucking up puddles. Link to comment Share on other sites More sharing options...
Kaan W Posted March 15, 2013 Share Posted March 15, 2013 Got ya! So what is it anyway? Link to comment Share on other sites More sharing options...
