Jamesc183 Posted March 14, 2013 Share Posted March 14, 2013 Changing my discs and ran into a sight problem'o Anyone know what to do when your handbrake adjuster has seized? I said please but it wouldnt move... Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 14, 2013 Share Posted March 14, 2013 Hit the disc with a hammer? Quote Link to comment Share on other sites More sharing options...
Iky Posted March 15, 2013 Share Posted March 15, 2013 Hit the disc with a hammer? This, but remember to buy a full handbrake fitting kit because chances are that by the time you've finished smacking it off, the internals will be mashed. Quote Link to comment Share on other sites More sharing options...
Benjy Posted March 15, 2013 Share Posted March 15, 2013 Tried some Rust off or GT85 type penetrants? Give it a squirt up, let it soak and then manipulate it back and forth with a screwdriver and a persuasion stick. Quote Link to comment Share on other sites More sharing options...
Jamesc183 Posted March 19, 2013 Author Share Posted March 19, 2013 Ok guys so I got my disc off today and replaced it with a new one.. Now I don't know how to go about fixing this handbrake adjuster problem? Do I just get new shoes or shall I order a set similar to this? Supra Handbrake Kit. Thanks in advance Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 19, 2013 Share Posted March 19, 2013 The adjuster is right in front of you, can you not move it? Also theres no adjuster in that kit. Quote Link to comment Share on other sites More sharing options...
Jamesc183 Posted March 19, 2013 Author Share Posted March 19, 2013 Yes mate it does not move. The left side one moves freely but this one doesn't budge!! Quote Link to comment Share on other sites More sharing options...
Jamesc183 Posted March 19, 2013 Author Share Posted March 19, 2013 Is there anyway this could be the RH handbrake cable?? Is it common for the handbrakes to seize? Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 19, 2013 Share Posted March 19, 2013 If the adjuster doesnt move then Id say thats the problem. If a soak in GT80 or WD40 doesnt sort it just got to Toyota and get a new one. Cables do seize but I wouldnt say its a common problem on modern cars. Quote Link to comment Share on other sites More sharing options...
Jamesc183 Posted March 20, 2013 Author Share Posted March 20, 2013 Ok thanks mate, ill try this tommoro! Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 20, 2013 Share Posted March 20, 2013 I'd buy a new one. Quote Link to comment Share on other sites More sharing options...
Jamesc183 Posted March 26, 2013 Author Share Posted March 26, 2013 Could this be the wheel cylinder not doing its job properly? I still haven't worked this out yet!! Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted March 26, 2013 Share Posted March 26, 2013 Dont have wheel cylinders, the hand brake is purely mechanical. Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 27, 2013 Share Posted March 27, 2013 Page BR-60 clearly shows the handbrake and all its partsBR.pdf Quote Link to comment Share on other sites More sharing options...
