T14PPA Posted March 13, 2013 Share Posted March 13, 2013 As im going single i want to change all fluids. Anyone recomend a good auto gearbox oil? Also for the tt auto diff? Link to comment Share on other sites More sharing options...
T14PPA Posted March 13, 2013 Author Share Posted March 13, 2013 Also is there an opie oil discount code for members? Link to comment Share on other sites More sharing options...
oilman Posted March 14, 2013 Share Posted March 14, 2013 Hi Due to the gearbox specs I would go for either the Amsoil ATF, Motul Multi ATF, Fuchs ATF4400 or Millers Millermatic ATF SPIII. http://www.opieoils.co.uk/c-442-atfs.aspx The discount code is M4SUPOC Cheers Tim Link to comment Share on other sites More sharing options...
Iky Posted March 14, 2013 Share Posted March 14, 2013 Hi Due to the gearbox specs I would go for either the Amsoil ATF, Motul Multi ATF, Fuchs ATF4400 or Millers Millermatic ATF SPIII. http://www.opieoils.co.uk/c-442-atfs.aspx The discount code is M4SUPOC Cheers Tim What do you reccomend for the Differential Tim? Link to comment Share on other sites More sharing options...
oilman Posted March 14, 2013 Share Posted March 14, 2013 LSD or open diff? Cheers Tim Link to comment Share on other sites More sharing options...
T14PPA Posted March 14, 2013 Author Share Posted March 14, 2013 LSD or open diff? Cheers Tim Im sure its lsd tim. Any recomendations? Thanks for your help Link to comment Share on other sites More sharing options...
Kaan W Posted March 14, 2013 Share Posted March 14, 2013 Im sure its lsd tim. Any recomendations? Thanks for your help I think it's an open diff mate I used millermatic type III in my transmission. Link to comment Share on other sites More sharing options...
T14PPA Posted March 14, 2013 Author Share Posted March 14, 2013 I think it's an open diff mate I used millermatic type III in my transmission. Why do you think that? Link to comment Share on other sites More sharing options...
Kaan W Posted March 14, 2013 Share Posted March 14, 2013 Why do you think that? I'm sure someone told me that mine was when I was gunno upgrade to an lsd but I could be wrong, is it the standard auto diff? Link to comment Share on other sites More sharing options...
ashbuster Posted March 14, 2013 Share Posted March 14, 2013 mines a lsd and mines auto mate Link to comment Share on other sites More sharing options...
T14PPA Posted March 14, 2013 Author Share Posted March 14, 2013 I thought all tt autos were. And im sure both wheels spin together so it must be lsd Link to comment Share on other sites More sharing options...
David P Posted March 14, 2013 Share Posted March 14, 2013 (edited) As im going single i want to change all fluids. Anyone recomend a good auto gearbox oil? Also for the tt auto diff? http://www.mkivsupra.net/vbb/showthread.php?56684-FAQ-Oil-Fluid-Interval-Capacity-Steering-Brake-Coolant-Diff-Engine&highlight=oil+spark+plugs I thought all tt autos were. And im sure both wheels spin together so it must be lsd If your Supra hasn't been tinkered with the vin plate code will tell you if it's Open or Torsen. A02A = Open = Number 1's. A02B = Torsen = Number 11's. Edited March 15, 2013 by David P (see edit history) Link to comment Share on other sites More sharing options...
Kaan W Posted March 15, 2013 Share Posted March 15, 2013 Both my wheels spin together but the back end always kicks left and the rear left tire has the least tread on it. So its not locking both up 1:1 but still spinning both. Is this a torsion? I thought an lsd had to be an aftermarket upgrade. Link to comment Share on other sites More sharing options...
David P Posted March 15, 2013 Share Posted March 15, 2013 Both my wheels spin together but the back end always kicks left and the rear left tire has the least tread on it. So its not locking both up 1:1 but still spinning both. Is this a torsion? I thought an lsd had to be an aftermarket upgrade. Supra's were supplied with either an Open or Torsen diff and labelled as above, there are also several different after-market options. Your left-kicking sounds like the geometry is in need of alignment and/or you could be losing traction on the muck that's not swept off the nearside road cambers these days. Link to comment Share on other sites More sharing options...
Kaan W Posted March 15, 2013 Share Posted March 15, 2013 Supra's were supplied with either an Open or Torsen diff and labelled as above, there are also several different after-market options. Your left-kicking sounds like the geometry is in need of alignment and/or you could be losing traction on the muck that's not swept off the nearside road cambers these days. So to clarify, neither an open type or tortion diff is a lsd? It could well be the geo actually. Link to comment Share on other sites More sharing options...
David P Posted March 15, 2013 Share Posted March 15, 2013 So to clarify, neither an open type or tortion diff is a lsd? It could well be the geo actually. Torsen is an abbreviation for Torque sensing LSD. You should try looking elsewhere on the interweb sometimes, it's amazing what can be learned without confusion from Old Supra Wives Tales. Link to comment Share on other sites More sharing options...
oilman Posted March 15, 2013 Share Posted March 15, 2013 Hi With either the open or LSD, go for a 75w-90. http://www.opieoils.co.uk/c-673-75w-90-mtfs-manual-transmission-fluid.aspx The Fuchs Syn 5, Millers CRX LS, Redline 75w-90 GL5, Motul Gear 300LS and Gulf Competition LS are ideal for open diffs and LSDs. The Fuchs Sintopoid, Castrol Syntrax Longlife, Millers TRX, Motul Motylgear, Mobil SHC and Amsoil FGR are also good choices for open diffs. Cheers Tim Link to comment Share on other sites More sharing options...
T14PPA Posted March 15, 2013 Author Share Posted March 15, 2013 Hi With either the open or LSD, go for a 75w-90. http://www.opieoils.co.uk/c-673-75w-90-mtfs-manual-transmission-fluid.aspx The Fuchs Syn 5, Millers CRX LS, Redline 75w-90 GL5, Motul Gear 300LS and Gulf Competition LS are ideal for open diffs and LSDs. The Fuchs Sintopoid, Castrol Syntrax Longlife, Millers TRX, Motul Motylgear, Mobil SHC and Amsoil FGR are also good choices for open diffs. Cheers Tim Thanks tim i never thought i was going to get my answer. Thanks for your help Link to comment Share on other sites More sharing options...
David P Posted March 15, 2013 Share Posted March 15, 2013 As im going single i want to change all fluids. Anyone recomend a good auto gearbox oil? Also for the tt auto diff? I thought all tt autos were. And im sure both wheels spin together so it must be lsd http://www.mkivsupra.net/vbb/showthread.php?56684-FAQ-Oil-Fluid-Interval-Capacity-Steering-Brake-Coolant-Diff-Engine&highlight=oil+spark+plugs If your Supra hasn't been tinkered with the vin plate code will tell you if it's Open or Torsen. A02A = Open = Number 1's. A02B = Torsen = Number 11's. Thanks tim i never thought i was going to get my answer. Thanks for your help Link to comment Share on other sites More sharing options...
T14PPA Posted March 16, 2013 Author Share Posted March 16, 2013 Thanks tim i never thought i was going to get my answer. Thanks for your help All done ive ordered from you guys. Titan gearbox and diff oil. Been very impressed with titan quality Link to comment Share on other sites More sharing options...
David P Posted March 16, 2013 Share Posted March 16, 2013 As im going single i want to change all fluids. Anyone recomend a good auto gearbox oil? Also for the tt auto diff? I thought all tt autos were. And im sure both wheels spin together so it must be lsd http://www.mkivsupra.net/vbb/showthread.php?56684-FAQ-Oil-Fluid-Interval-Capacity-Steering-Brake-Coolant-Diff-Engine&highlight=oil+spark+plugs If your Supra hasn't been tinkered with the vin plate code will tell you if it's Open or Torsen. A02A = Open = Number 1's. A02B = Torsen = Number 11's. Thanks tim i never thought i was going to get my answer. Thanks for your help All done ive ordered from you guys. Titan gearbox and diff oil. Been very impressed with titan quality T14PPA, Could you please explain your selective blindness and bi polar manners? Link to comment Share on other sites More sharing options...
oilman Posted March 17, 2013 Share Posted March 17, 2013 Thanks for the order Link to comment Share on other sites More sharing options...
David P Posted March 18, 2013 Share Posted March 18, 2013 T14PPA, I've re-worded the question. Please explain why you don't have the testicles to explain why you're behaving like a vagina? Link to comment Share on other sites More sharing options...
T14PPA Posted March 18, 2013 Author Share Posted March 18, 2013 What are you on about Link to comment Share on other sites More sharing options...
David P Posted March 18, 2013 Share Posted March 18, 2013 What are you on about I spend quite a lot of time and effort answering members questions, it took me ages to find Alex's chart and the sequence of events bothered me. I answered two of you questions, both of which you ignored which is becoming common practice on here these days, so I post a reminder to jog your courtesy button. Yet then, not only but also, you then turn up and post thanks to others correctly, if that doesn't equal very smelly bad manners then I wasn't brought up proper. That's all. Link to comment Share on other sites More sharing options...
