hodge Posted March 12, 2013 Share Posted March 12, 2013 Would there be any advantage to using 5.1 fluid for my clutch. I know there's a huge difference when swapping dot 4 for 5.1 in the braking system, but is it worth it in the clutch lines. Thanks John Quote Link to comment Share on other sites More sharing options...
chrispot Posted March 12, 2013 Share Posted March 12, 2013 there would no advantage in using dot 5.1 over dot 4, as you may be aware dot 5.1 has a higher boiling point, dry and wet (3% water content). there is only about 40 degres difference between dot 4 and dot 5.1. if it were my car i would just buy dot 5.1 for the brakes and use the same for the clutch, brake fluid should be changed every 2 years regardless of mileage. Quote Link to comment Share on other sites More sharing options...
hodge Posted March 12, 2013 Author Share Posted March 12, 2013 I'll use 5.1 then if its got a higher boiling point seems I'm running a 4.5 inch downpipe and it's pretty close to the master cylinder. Quote Link to comment Share on other sites More sharing options...
Paul Whiffin Posted March 13, 2013 Share Posted March 13, 2013 Motul RBF660 is what we use on track cars. Quote Link to comment Share on other sites More sharing options...
Dnk Posted March 13, 2013 Share Posted March 13, 2013 Motul RBF660 is what we use on track cars. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 20, 2013 Share Posted March 20, 2013 Anything, no need for something exotic unless the slave cylinder is near a source of extreme heat, and then you would be far better of insulating it. Clutch fluid is under no duress at all. Quote Link to comment Share on other sites More sharing options...
garethr Posted March 20, 2013 Share Posted March 20, 2013 If the high temperature performance isn't needed you might be better off with DOT 3 because, IIRC, DOT 4 and 5.1 are more hygroscopic and would have to be changed more frequently. Quote Link to comment Share on other sites More sharing options...
hodge Posted March 21, 2013 Author Share Posted March 21, 2013 Anything, no need for something exotic unless the slave cylinder is near a source of extreme heat, and then you would be far better of insulating it. Clutch fluid is under no duress at all. Thanks Chris. I've just stuck some DOT 4 in. It's just what I had lying around in the shed. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted March 21, 2013 Share Posted March 21, 2013 Thanks Chris. I've just stuck some DOT 4 in. It's just what I had lying around in the shed. That's fine, no need to waste expensive fluid on most clutches Quote Link to comment Share on other sites More sharing options...
