SupraStar 3000 Posted March 10, 2013 Share Posted March 10, 2013 Stunning! You'll find away to fit them. Link to comment Share on other sites More sharing options...
marcAB10 Posted March 10, 2013 Share Posted March 10, 2013 Cheers James, I will Pm him and check Yes i run a 265 on 11" rears.. the stretch is noticeable and i would say it will need to be low with an aggressive offset so the stretch doesn't look weird. I run Falken 452's and have had zero issues running this size and set up. Link to comment Share on other sites More sharing options...
Kaan W Posted March 10, 2013 Share Posted March 10, 2013 As Jamie said machine the back off if there's enough meat on them. Theres definitely room one way or another Parry_10 had 12j wheels with them arches Link to comment Share on other sites More sharing options...
Swampy442 Posted March 10, 2013 Share Posted March 10, 2013 Nice looking wheels As above stretch the tyres, or cant you trim the arch? Also leave them gold, looks great Link to comment Share on other sites More sharing options...
DodgyRog Posted March 10, 2013 Author Share Posted March 10, 2013 They look stunning!, I would try to fit these. I noticed on my car, the more the wheels get up towards the arch, the bigger the camber gets, so you might actually get away with it. I can't drop the car much, as the diffusser will scrap, on all the speed bumps around the area I live They look much better, maybe machine a few mm off the back of the wheel, I've done that loads of times. As Jamie said machine the back off if there's enough meat on them. Theres definitely room one way or another Parry_10 had 12j wheels with them arches Thanks, I will look into that if necessary they will look awesome once refurbed mate, definately keep them Stunning! You'll find away to fit them. I have agreed a deal to buy them now, so they will have to fit somehow Yes i run a 265 on 11" rears.. the stretch is noticeable and i would say it will need to be low with an aggressive offset so the stretch doesn't look weird. I run Falken 452's and have had zero issues running this size and set up. [ATTACH=CONFIG]165578[/ATTACH] That's good to know Marc, mine are Falken 452's as well, it will probeerbly only be for this set of tyres and I will go up a size when I need new ones Nice looking wheels As above stretch the tyres, or cant you trim the arch? Also leave them gold, looks great Triming the arch isn't really an option as they may catch as the wheel goes inside the arch anyway I think the answer is the stretched tyre with a fairly stiff Coilover adjustment and not to low and they may be Gold for a while, but will definately be going Black eventually Link to comment Share on other sites More sharing options...
Abz Posted March 10, 2013 Share Posted March 10, 2013 If they don't fit then make them fit!! Your car deserves a wider stance to fulfil the kit, would look amazing. Link to comment Share on other sites More sharing options...
Jos Posted March 10, 2013 Share Posted March 10, 2013 I can't drop the car much, as the diffusser will scrap, on all the speed bumps around the area I live I understand, that was not what I ment, but when the wheel bounces in it might just clear your arch, because of the extra camber that is generated then. I thought my wheels were sticking out too, but when I removed my springs and tried lifting the suspension and wheel up in the arch I noticed the top of the wheel moves inside, so they fitted perfectly Link to comment Share on other sites More sharing options...
Noz Posted March 10, 2013 Share Posted March 10, 2013 raise the car? Link to comment Share on other sites More sharing options...
jazz1 Posted March 10, 2013 Share Posted March 10, 2013 Coilovers you will be fine mine stick out slightly I run HKS III. Link to comment Share on other sites More sharing options...
uksuprakev Posted March 11, 2013 Share Posted March 11, 2013 mate these look mint with prospect of black centers an peeled rim would only add to the look hope you get em to fit mate . Link to comment Share on other sites More sharing options...
DodgyRog Posted March 12, 2013 Author Share Posted March 12, 2013 (edited) If they don't fit then make them fit!! Your car deserves a wider stance to fulfil the kit, would look amazing. I agree Abz, my Supra really needs deep dish and these are really deep deep deep dish I understand, that was not what I ment, but when the wheel bounces in it might just clear your arch, because of the extra camber that is generated then. I thought my wheels were sticking out too, but when I removed my springs and tried lifting the suspension and wheel up in the arch I noticed the top of the wheel moves inside, so they fitted perfectly Sorry, got you now though raise the car? Monster Truck Supra:eyebrows: Coilovers you will be fine mine stick out slightly I run HKS III. http://i556.photobucket.com/albums/ss4/jass897/E93212B4-85EA-45A1-B82B-6D40C1D6988B-1536-000001DD9CB15C16.jpg I am going to run a stretch I think, as the rear tyres on them a shot anyway, but I think I will save a bit more cash up and look at putting a 285 on and doing what you have done with yours mate these look mint with prospect of black centers an peeled rim would only add to the look hope you get em to fit mate . They better be worth the effort, sa Jen is not amused, as my spending was supposed to have finished for the rest of this year Edited March 12, 2013 by DodgyRog (see edit history) Link to comment Share on other sites More sharing options...
k2supra Posted March 12, 2013 Share Posted March 12, 2013 What is the smallest tyre I can put on an 11 inch rim Sensibly without risking it coming off Why put a big wheel on there then not bother putting a fat tyre on there? Seems like a waste to me... Link to comment Share on other sites More sharing options...
ellis Posted March 12, 2013 Share Posted March 12, 2013 Coilovers you will be fine mine stick out slightly I run HKS III. http://i556.photobucket.com/albums/ss4/jass897/E93212B4-85EA-45A1-B82B-6D40C1D6988B-1536-000001DD9CB15C16.jpg Another quality pic from you mate!! Nice finger! Link to comment Share on other sites More sharing options...
jazz1 Posted March 13, 2013 Share Posted March 13, 2013 Another quality pic from you mate!! Nice finger! You can't beat it , its pro shot lol. Link to comment Share on other sites More sharing options...
DodgyRog Posted March 13, 2013 Author Share Posted March 13, 2013 Why put a big wheel on there then not bother putting a fat tyre on there? Seems like a waste to me... Because With buying the wheels and a refurb I won't have any spare money for a bit and have 265's already In the last 6 months I have done a TT engine transplant, gone BPU+, had some bodywork done, bought a few smaller bits and pieces as you do and now the wheels, So my bank balance is really not looking good now and not going to for a fair while I am guessing Link to comment Share on other sites More sharing options...
DodgyRog Posted March 13, 2013 Author Share Posted March 13, 2013 Another quality pic from you mate!! Nice finger! You can't beat it , its pro shot lol. I did think the same, but thought I wouldn't say anything, as it was nice of Jazz to go to the effort lol We do have some amazing photographers on this forum Link to comment Share on other sites More sharing options...
DodgyRog Posted March 22, 2013 Author Share Posted March 22, 2013 Think these should provide enough dish:d Link to comment Share on other sites More sharing options...
Crash Bandicoot Posted March 22, 2013 Share Posted March 22, 2013 How much for the Kitkat mate? - - - Updated - - - If your on a tight budget you should consider how much choccy bars cast now a days! Link to comment Share on other sites More sharing options...
GreaseMonkey Posted March 22, 2013 Share Posted March 22, 2013 Just a thought, a girl I know on the Skyline Owners forum is selling a set of these Volks wheels which may be a better fit width wise/might be worth a look at? if youv'e not purchased these other wheels yet. http://www.skyline-owners-club.com/forums/showthread.php?t=44350 Link to comment Share on other sites More sharing options...
