shaz2010 Posted March 12, 2013 Share Posted March 12, 2013 I think you ( Fosta ) and me are the enlightened ones on this thread. And as more and more, get it done, it will end up being better than having an Irish hand crank with your left hand. I'm going to give it a try. Link to comment Share on other sites More sharing options...
supra joe Posted March 12, 2013 Share Posted March 12, 2013 I'm going to give it a try. Me too lol. Link to comment Share on other sites More sharing options...
jazz1 Posted March 12, 2013 Share Posted March 12, 2013 I think it would work, people told me Auo-rx was snake oil but it does work as it cleared my low compression etc. Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted March 12, 2013 Share Posted March 12, 2013 Ah, now I'm a disbeliever again with that nonsense +1 lmao Link to comment Share on other sites More sharing options...
FOSTA Posted March 12, 2013 Share Posted March 12, 2013 (edited) Edited: Edited March 12, 2013 by FOSTA (see edit history) Link to comment Share on other sites More sharing options...
lewysdanny Posted March 12, 2013 Author Share Posted March 12, 2013 Cooool dude... Link to comment Share on other sites More sharing options...
imi Posted March 13, 2013 Share Posted March 13, 2013 Looking forward to the results Link to comment Share on other sites More sharing options...
TT Paul Posted March 13, 2013 Share Posted March 13, 2013 dyno booked 28/3 earliest i could get Link to comment Share on other sites More sharing options...
Digsy Posted March 13, 2013 Share Posted March 13, 2013 What are you planning? A before and after run? Link to comment Share on other sites More sharing options...
listy Posted March 13, 2013 Share Posted March 13, 2013 What are you planning? A before and after run? Before has already been done iirc Link to comment Share on other sites More sharing options...
Dragonball Posted March 14, 2013 Share Posted March 14, 2013 I will be happy to get my 535d tried out - have a before and can arrange an after I cant find the group buy thread that Jazz started? Link to comment Share on other sites More sharing options...
jazz1 Posted March 14, 2013 Share Posted March 14, 2013 I did not consent the mods, I'm going call another company before I re open another group buy thread with the consent of the Mods. Give me a couple days as I'm bit buisy at work exams etc. Link to comment Share on other sites More sharing options...
Digsy Posted March 14, 2013 Share Posted March 14, 2013 Before has already been done iirc Depends on how it was done though. IMHO to do a real test of this you would want to do a baseline dyno and emissions test. I'd want to see three dyno runs before and after to check the repeatability of the figures. There's no point claiming 5% improvement in torque if the dyno varies by 3% from one run to the next Ideally the before and after would want to be done close enough together that there wasn't a massive temperature and atmospheric pressure change between the two, but the figures could be corrected for that afterwards (if the dyno doesn't do it automatically). The oil level should be checked before each set of runs to make sure it is exactly the same (crankcase windage robs more power than you might think). For the emissions test, one test before and after would do but the car would need to be prepped for each test the same way beforehand. Letting it go completely cold and then warming it up as if it was doing a test for the MOT should suffice. None of this doing the Terraclean and then immediately sticking a sensor up the tailpipe while the engine is stinking hot business. For fuel consumption I would want to see the car used as repeatably as possible for a full tank of fuel with the mileage being logged and the amount of fuel used being recorded at the pump (brimmed to start and then brimmed at the end to measure the difference). using the car as your daily drive / commute should be a good way of getting through a full tank quickly and in as repeatable style of driving as possible. Real world fuel economy figures are measure at very low speeds and loads, so going for a blat down the nearest private test track won't produce useful numbers. Mind you, I have a record of MPG for nearly every single tank full I have ever put in my Supra over 11 years of ownership and even those figures vary by about +/-3mpg from tank to tank, so again a big pinch of salt required there. The best way to do it would be to measure the injector duty cycle for a set speed / load point (2000RPM / 2bar BMEP is a favourite). Very steady right foot required And a bore scope inspection before and after would be useful, but obviously a big ask As well as seeing the results first hand, there is a danger of getting a false negative if your engine isn't coked up to start with! A big pain in the bum to do, but that's the scientific method for you! Link to comment Share on other sites More sharing options...
Graham1984 Posted April 13, 2013 Share Posted April 13, 2013 Any updates to this from the people who have had it done or the new dyno print? Link to comment Share on other sites More sharing options...
mellonman Posted April 13, 2013 Share Posted April 13, 2013 Maybe gone quite as there is no results to report back Link to comment Share on other sites More sharing options...
TT Paul Posted April 13, 2013 Share Posted April 13, 2013 see my thread Link to comment Share on other sites More sharing options...
DaveR Posted April 13, 2013 Share Posted April 13, 2013 see my thread Not promising... Click. Link to comment Share on other sites More sharing options...
mellonman Posted April 13, 2013 Share Posted April 13, 2013 see my thread Just see your thread , so the results are bad then , but the case maybe like I said earlier in the thread if it did work it may have cleaned the injectors so now they may flow better and you may be running just slightly richer making less power , do you see my point? Link to comment Share on other sites More sharing options...
