Fuel pressure reg HELP
T14PPA
I have got a fuel pressure regulator and im unsure how to fit it.
Heres the fpr
I thought i have to put an adapter where the original is. Connect from the adapter to the side nipple on fpr. And join the bottom nipple to the stock pipe that was conected to the old fpr. Am i corrct?
Whats wrong with your stock reg?
Kits are normally supplied with an adapter that replaces the stock rail return, this goes to the input port on the reg (normally on the side), the output (normally on the bottom) is then routed back to the tank.
As im going single i thought i would need it. They do an adapter on whiftbitz website. Then i can just replace the stock one with the new
Its not a requirement ;)
Unless you are going for a complete fuel system or ramping up the base fuel pressure to squeeze more from undersized injectors then the stock reg is fine.
I have 800cc injectors. Im looking for 600bhp. What do you think i should do?
Well since I am running 590hp with a stock reg and 650cc drop ins I would say you are prob fine, the only fuel system mods I have are injectors and pump, everything else is stock including fuel pulsation dampner which I keep meaning to replace but never got round to it :D
I might leave it depending on if i find adapters and a way to fit it
  • 4 weeks later...
You brought one of those cheap chiense FPR's? I would change that mate :) I fitted a Aeromotive one as you know your getting a good product.
Remember mate, if that goes wrong thats high pressure fuel spraying into your engine, or running lean and melting something.
Just read this!
http://www.theturboforums.com/threads/306142-So-I-got-my-eBay-FPR-BOV-Intercooler-and-Wastegate-time-to-dissect
