scott87 Posted March 5, 2013 Share Posted March 5, 2013 (edited) Ok i know im going to need a socket to remove the knock sensor but what size will it need to be and i assume it will need to be a deep socket. If anyone can advise that would be great. I should probably ask for the title to be changed to what size socket on reflection. Edited March 5, 2013 by scott87 (see edit history) Link to comment Share on other sites More sharing options...
Tyson Posted March 5, 2013 Share Posted March 5, 2013 you can do it yourself just edit your original post. Link to comment Share on other sites More sharing options...
scott87 Posted March 5, 2013 Author Share Posted March 5, 2013 you can do it yourself just edit your original post. I was about to post i have forgotten how. Then remembered! Link to comment Share on other sites More sharing options...
scott87 Posted March 6, 2013 Author Share Posted March 6, 2013 Anyone? Link to comment Share on other sites More sharing options...
d-_-b Posted March 6, 2013 Share Posted March 6, 2013 Can't confirm the size but can confirm it will need to be a deep socket due to the electrical connector on the end of it. Link to comment Share on other sites More sharing options...
scott87 Posted March 6, 2013 Author Share Posted March 6, 2013 b;3615555']Can't confirm the size but can confirm it will need to be a deep socket due to the electrical connector on the end of it. Yer thats what i thought thanks. Just need to work out the size Link to comment Share on other sites More sharing options...
Scooter Posted March 6, 2013 Share Posted March 6, 2013 27mm Link to comment Share on other sites More sharing options...
scott87 Posted March 6, 2013 Author Share Posted March 6, 2013 27mm Wow ok didnt think it was that big. The starters gotta come off then! Link to comment Share on other sites More sharing options...
Scooter Posted March 6, 2013 Share Posted March 6, 2013 why do you say that? Link to comment Share on other sites More sharing options...
scott87 Posted March 6, 2013 Author Share Posted March 6, 2013 why do you say that? Doesnt look like a 27mm will fit past it? Could be wrong, not that its hard to undo the 2 bolts on the starter.... If it will just bolt straight out thats an even better job Link to comment Share on other sites More sharing options...
Scooter Posted March 6, 2013 Share Posted March 6, 2013 (edited) I'd have thought coming at it from above might be easier? Edited March 6, 2013 by Scooter (see edit history) Link to comment Share on other sites More sharing options...
scott87 Posted March 6, 2013 Author Share Posted March 6, 2013 The intake is way. You have to go between something and the starter. Link to comment Share on other sites More sharing options...
Scooter Posted March 6, 2013 Share Posted March 6, 2013 I have an engine in the garage, I'll try and see what's involved with the rear sensor, I measured the front knock sensor which is directly accessible by a socket from the side. Link to comment Share on other sites More sharing options...
scott87 Posted March 6, 2013 Author Share Posted March 6, 2013 Spot on thanks :-) Link to comment Share on other sites More sharing options...
