Traction control problem
ronttuk
The car UK spec 1994 auto.
This started in the cold weather first i had a brake warning light on then the traction control light came on,I topped up the brake fluid and both lights went out then the traction button didnt seem to do anything no lights on dash if it was pushed in or out, now if i push the button in I get the red warning triangle and the trac light on next to the oil pressure light etc,im not sure if traction control is working or not now before if i pushed the button i got a different light to say traction control off.
So could it be the switch? or a sensor? or the pump? i dont get any fault codes.
