Cisco advice?
GeordieSteve
Hmmm.... maybe. What is the 501, a switch?? Not familiar with it. It could restrict things you want to restrict (e.g. certain IP address range(s) only, certain ports only) however (and the new unit will need to be configured to provide the same security) or, it could be doing some NATing (likely), or similar, which the new unit may need to be configured in order to work.
Hmmm.... if you send me the config file from the Firewall (and the current ADSL router if it's Cisco?) - i.e. copy & paste the text after doing a "show run" (if you're allowed to!!) - I can take a look and tell you if there is anything that will need jigging. :)
*BOWS DOWN* Cheers dude, much appreciated. I'm going to listen to what the nasty pastys at the other IT company say then I'll post it up. Should really do a Cisco course I suppose
I'd recommend one of our training partners....5i
Good bunch of lads and excellent traning programs.
