Single Turbo conversion checklist?
listy
There are only a few lists of "this is what I've got, what else do I need."
Effectively, I'm looking for a list that comprehensively states what you need for a bare minimum single build, plus recommended extras, that can maybe be made into a sticky, to avoid more threads like this one ;)
Brand names etc are not important, as we all know people get what they can afford and what is suitable for their aims.
Will be worth getting in touch with the traders as they will be able to say straight away what's needed too (including the bits that aren't necessarily at the front of peoples minds), it's a good idea having a sticky with this :)
When I first started my build spec I never realised half of what was needed/advised to be replaced, think my parts list tripled lol, but I do want it bulletproof ;)
Edited by Littler (see edit history)
Electric and Fuel System:
Syvecs SP6
Options
1. 1.0 bar - Low boost
2. 1.2 bar
3. 1.4 bar
4. 1.6 bar - High boost
5. Lean cruise/MOT
6. Antilag
7. Anti-theft
8. Valet mode
Toucan Multi Display
AEM Wideband AFR Gauge-
HKS 1000cc injectors, twin entry rail, adjustable fpr and braided return hose to connect to stock return line
Turbo Kit:
HKS T04Z
This kit includes HKS' newest Garrett-based turbo. It is a 63T Trim with a 1.00 A/R exhaust housing and the normal T04 style flange. This kit is capable of about 750rwhp and spools quicker than virtually any other kit on the market for the power it makes.
This kit utilizes the famous HKS GT S/S Exhaust Manifold and HKS GT2 Wastegate, the best on the market.
HKS oil cooler and relocation kit
Greddy 4 core FMIC
Koyo Rad
Spark Plugs NGK R7436-9
1 head gasket
Jun Plenum with flow work done
Custom 4'' Exhaust from downpipe back
Billet Water Pump Pulley - Silver
Billet PS Pump Puley - Silver
TRD New Thermostat
Twin Fan Set up
Bonnet damper kit
New OEM Coil Pack, leads/cord, clips
Built Head:
SRD 264 Cams
Intake kit w\ filter 4"
Drive Train:
V161 Gatrag 6 speed
Gilken Tripple Plate Carbon Clutch Kit
Brakes:
Endless Complete front and rear 'callipers, disks and pads'. 15'' disks front 13'' rear.
Tyres:
Toyo R888 295/30/19
Toyo R888 255/35/19
Bits and pieces:
1) Hose & fittings for header breather to back of car complete PnP – Just need to weld fitting on cam cover----
2)1x 264 Exhaust Cam SRD
3) Battery to boot kit + billet battery tray.
4) Toyota Celica Throttle Cable----
5) Toyota Head Gasket Kit----
6) Cam Belt----
7) Aux Belt----
8) Billet belt tensioner 'cam belt-----
9) Air Filter 4'' PnP Hose 'Blue' and Clamp – Yes it is 4" Pipe?-----
10) FMIC PS Relocation and alloy catch tank - PnP blue hose and clamps----
11) Toyota Idler Wheel for timing belt----
12) Boot Rubbers-----
13) Hose and clamp only - for hard pipe from upper radiator to engine water neck – Special offer ;-)
14) 8 Position Calibration Switch----
15) 4 Bar Mapsensor Kit with plug----
16) 3 Port Boost Solinoid----
17) Bosch Wideband Knock Sensor----
18) EGT Sensor------
19) Supra Loom adaptor----
20) Oil temp sensor-----
21) Oil Pressure Sensor-----
22) NTK Wideband Sensor-----
23) Fuel Pressure Sensor ----
24) Toucan Display -----
25) TRD Engine Mount and Connector ----
26) SRD Twin Fan Kit
27) Greddy Gear Knob
28) New OEM Boot Strut
29) Syvecs ECU
Syvecs SP6
Options
2. 1.2 bar
3. 1.4 bar
5. Lean cruise/MOT
6. Antilag
7. Anti-theft
8. Valet mode
Turbo Kit:
HKS T04Z
Greddy 4 core FMIC
Koyo Rad
1 head gasket
TRD New Thermostat
Twin Fan Set up
Bonnet damper kit
Built Head:
SRD 264 Cams
Drive Train:
V161 Gatrag 6 speed
Brakes:
Tyres:
Toyo R888 295/30/19
Toyo R888 255/35/19
Bits and pieces:
6) Cam Belt----
7) Aux Belt----
29) Syvecs ECU
Thanks, but not really what I'm after. Although everything is there, I'm literally looking for what is NEEDED, what is RECOMMENDED, and other parts that can be added to make it better.
I'll PM the likes of Paul and Lee, and see what input they have :)
Have you got the single turbo kit yet.
I'm not single yet, but am planning on it in the future.
I just noticed there was no sticky thread on it, and thought one would be beneficial for all :)
- - - Updated - - -
Yes, yes it is :D
Thanks very much dude.
I've PM'd Lee and Paul for their input on what they consider the minimum, recommended, and worthwhile extras to be, so I'll see what they say too.
I'll have a trawl through that thread and try and find a comprehensive list, as after a quick look, it seems more like a discussion, than a "this IS what is needed".
Just skimmed through that thread, and it seems to have just died off.
Rather than going by "this is what i have" opinions, I'd rather gain a "professional" opinion (or in this case, two) on what is required, from Lee and Paul, as there aren't many who know better than SRD or Whifbitz ;)
