Help with stereo wiring PLEASE.
Crash Bandicoot
Just took dash out and removed the after market double din cd player, the wires from the car to the CD player via two black boxes/plug ins... Problem is someone has cut the boxes/plug ins off and spade connected everything, I'm going to chop the box/plug ins off mine and spade my CD player into where the old one is.
I understand the speaker wires and the big yellow permanent 12v but don't know about the rest.
Can anyone help? Hopefully with knowledge of what colour wires the car side do/supply what. All info extremely appreciated! :)
Yellow - Ignition
Red - Constant
Black - Earth
Blue - Remote for amp
Orange - Lighting
Thats pretty uch all you need, also if settings and radio stations reset everytime you switch the ignition off swap the red and the yellow around.
Before you do any cutting get a look on Ebay as I'm positive they do the replacement stereo loom from the white connectors further back ....thus giving you the black box connectors that you have missing .......less than a fiver too ;)
  • 2 weeks later...
Cheers for the posts guys. I had to cut and connect it as it was cut the car side, so had nothing to plug and play into. Made my speaker brackets now, just trying to find out which is positive and negative in the doors now.
I think this is the same as mine I just have a white thick wire with little ones inside is this the same as yours?
