FOSTA Posted March 2, 2013 Share Posted March 2, 2013 Hi guys could anybody tell me where the fuse is for the fuel pump? Cheers Quote Link to comment Share on other sites More sharing options...
Kaan W Posted March 2, 2013 Share Posted March 2, 2013 Have you checked the fusebox in the footwell? Quote Link to comment Share on other sites More sharing options...
Ian C Posted March 2, 2013 Share Posted March 2, 2013 EFI #2 in the engine bay fusebox. 30 amps. Quote Link to comment Share on other sites More sharing options...
FOSTA Posted March 2, 2013 Author Share Posted March 2, 2013 EFI #2 in the engine bay fusebox. 30 amps. So if I remove that dose it only disable the fuel pump? For example if I was to hook up a external pump and connect that to the fuel rail and block off the return so the fuel I put through Dosnt just run back into the supra fuel tank would the car start ? Obviously I will set the external fuel pump to the correct pressure. Quote Link to comment Share on other sites More sharing options...
